Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Advans fitement
Old Mar 25, 2010 | 10:09 AM
Zydas's Avatar
Advans fitement
Does evo fit advan rz 19x10 +35 ? Because i allready ordered and some people say that it's not good.
Old Mar 25, 2010 | 10:29 AM
Zydas's Avatar
Does it look good on evo x?
Old Mar 25, 2010 | 11:42 AM
Ah10's Avatar
19x10 et35 will fit, it would look better with et25
Old Mar 25, 2010 | 11:49 AM
Zydas's Avatar
What will be the difference?
Old Mar 25, 2010 | 11:59 AM
Zydas's Avatar
It will be big difference or just small one?
Old Mar 25, 2010 | 12:03 PM
healthynine's Avatar
They won't be as concave and won't fit as flush...not a huge difference. You could run spacers but still not as concave
Old Mar 27, 2010 | 11:59 AM
TRACE on's Avatar
That size may not clear the shock towers (i.e. may require spacers).
Taken from:
https://www.evolutionm.net/forums/ev...ent-chart.html
Stock wheels clearance to front shock: 22mm
19x10 +35 moves toward front shock: 16mm
New front clearance: 6mm
Stock wheels clearance to rear shock: 13mm
19x10 +35 moves toward rear shock: 16mm
New rear clearance: -3mm
Old Mar 28, 2010 | 12:01 PM
Red Rum's Avatar
25 offset will sit outside the fender a few millimeters. At full turns, 265/30 tires will barely rub the inside plastic wheel wells (not a big deal to me). They will clear both stock suspension or aftermarket coilovers just fine.
35 offset will sit just inside the fender wells....
Look through the aggressive wheel thread to see what look/ offset you like. Good luck.
dillons13
For Sale - Wheels / Tires
Jun 15, 2017 09:17 PM
danielskshin
Apr 19, 2012 06:05 AM
jkc213
19
Aug 13, 2011 11:01 PM
Zydas
10
Dec 5, 2008 02:33 PM
apexstrafer
30
Mar 28, 2004 04:00 PM
