Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Rear caliper guide pin
Old Jun 11, 2010 | 03:06 AM
Johnr352's Avatar
One of my pins broke, cracked right through, when I removed it to swap the pads. I've never heard of this happening before but, sure enough...
Does anyone know whether the Evo IX rear calipers use the same size guide/ retaining pin(s) to hold the brake pads? The replacements are a little easier to find.
Anyone have a good source for these pins? The dealer can order them but they don't seem readily stocked.
Old Jun 11, 2010 | 07:45 AM
Johnr352's Avatar
OK, a source of these pins is the "clip and pin kit" is your friendly dealer for $49.95 and includes 4 pins and two clips. Buy one of these if you go to the track. If you lose a pin you'll be stuck and, I suspect, unhappy.
You might be able to find these kits online for less, order one now.
