Coilover Question - Need Help!
So i was tackling on the coilover swap and everything was going smoothly until a couple of minutes ago. I was on the process of installing the kw coilover and noticed that the screw where the brakeline bracket screws onto does not match at ALL... i dont want to try and force it in because i dont want to bend the brake lines... anyone have any idea why the hell this is happening? i've been trying to fix it for the past 2 hours... ugh.. Here are some pics
Help!!
Help!!
Solved it, i was being a little too cautious when it came to bending the brake lines a tad, i started flexing the brake lines enough to get the nut threaded. Then just torqued it to the correct number. Its all good. I finished both front coilovers and starting on the back ones tomorow. Should be nice!
Next time though, use the macro setting on your camera!
