Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
brake cooling question...
Old Jul 21, 2010 | 11:30 AM
phillyexox's Avatar
can a brake caliper duct like this be purchased for an evo x, or does it have to be custom made? any help would be great, thanks!
Old Jul 21, 2010 | 01:18 PM
blk-majik's Avatar
AMS makes a brake ducting package, but I don't think it gets welded to the back of the hub like that one. I think it just mounts on using the caliper mounting bolts. Other people have also rigged (ie: ziptied) brake cooling ducts from a Porsche 911 gt3's to their control arms to redirect air passing under the car onto the brakes. This seems to a quick and cheap way to fix the problem
http://www.amsperformance.com/cart/A...oling-Kit.html
http://cgi.ebay.com/ebaymotors/PORSC...Q5fAccessories
Old Jul 21, 2010 | 04:33 PM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Why not just get the ones the mitsu makes for the car?
Old Jul 21, 2010 | 04:50 PM
jkapinos's Avatar
The one in the picture is the AMS kit I have it.
Old Jul 21, 2010 | 05:06 PM
Crester's Avatar
You mean those air guides that direct the air towards the brake? How would that compare to actually ducting a pipe of air to the caliper?
Old Jul 21, 2010 | 05:09 PM
Crester's Avatar
Here's the thread on the guy who used Porsche air guides on his car.
https://www.evolutionm.net/forums/ev...e-30-hour.html
Old Jul 21, 2010 | 05:23 PM
H Jensen's Avatar
That's not welded onto the hub, its welded to a sheet that is bolted to the hub.
Old Jul 21, 2010 | 05:28 PM
ahhhhhhh....I guess that be better for track days....I thought it was about the same concept except this is actually applied to the brakes and focused more on the brakes....
Old Jul 21, 2010 | 06:50 PM
phillyexox's Avatar
I'm more interested in getting a tube directly to the brake caliper. the Porsche guides also would hang too low for me.
Old Jul 22, 2010 | 08:12 AM
phillyexox's Avatar
that picture is the one from the ams kit but $500 is a little pricey for the full kit which is why i would like to find these caliper ducts seperately.
Old Jul 22, 2010 | 12:54 PM
mlomker's Avatar
You could probably have some custom fabricated and still come out cheaper. I'm amazed that no vendor has come out with a competing kit.
Old Jan 10, 2011 | 09:17 AM
goofygrin's Avatar
Perhaps something like this would work for you? TCB approved!
Old Jan 12, 2011 | 12:21 PM
chu's Avatar
chu
Probably due to the lack of demand.
Old Jan 12, 2011 | 12:40 PM
TxEvo8's Avatar
I bought the Binary ducts (~$125), they are just like the piece pictured above, then you have to find the tubing and inlets for a much cheaper option.. jid2 is his user name.
Old Jan 12, 2011 | 01:32 PM
krisiun's Avatar
I contacted jid2 about the brackets for an Evo X. He said he wasn't sure that they would fit the Evo X, he would check and get back to me....that was months ago.
