Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Rota svn + tpms???
Old Jan 22, 2011 | 10:11 PM
jkc213's Avatar
Rota svn + tpms???
i got the rota svn and went to a shop to install them..
they say my sensor won't fit with the new wheels..
can anyone confirm this with the same set of wheels???
now i have this (!) on my dash.. lol
thanks...
Old Jan 22, 2011 | 11:39 PM
evox23's Avatar
i have rota svn 18x10.5 in gunmetal, i took it to a local tire installer and they never had a problem installing it. 8k miles on them and still fine. your concern will be how they will balance it, and where to put the weights...theres a thread for it on this site...easy...looks sick and aggressive...
Old Jan 22, 2011 | 11:45 PM
jkc213's Avatar
hmmmm, should i try bring it to another shop?? probly they dont know how to install this back..
Old Jan 23, 2011 | 06:13 AM
Robevo RS's Avatar
some wheels will have a different wall design which will not let certain type of tpms sensor sit in right on them, i heard that before.
It is actually not the Rota design fault, if that really happens then you can blame some "bigger names " legitametly. Im sure you know why ... LOL
Old Jan 24, 2011 | 02:01 PM
dan avoN7's Avatar
The OEM TPMS sensors are compatible with the Rota SVN regardless of the wheel size (18x9 or 18x10 "R"). I would suggest having another tech look at it or take it to another shop.
Now depending on the wheel size.. you may have to mount the wheel weights further in on the wheel barrel. The Rota SVN-R (18x10 +20) has such a large lip that it limits caliper clearance. Due to the lip you will have to mount the wheel weights further in on the caliper side so that they don't contact the caliper.
Old Jan 24, 2011 | 02:14 PM
jkc213's Avatar
I got the 18x9 svn, went to firestone(2nd shop) and same result, they say It won't fit beacuse of the wheel design... Before I purchase the wheel did some research found that they will fit.. I'll try my luck to the dealer and will see..
Old Apr 29, 2011 | 02:07 PM
andrewzaragoza's Avatar
what wheel size do you have?
Old May 6, 2011 | 02:16 PM
jkc213's Avatar
18x9 +22
AntilagtunedMR
May 23, 2017 12:58 PM
mcjallen
Mar 20, 2012 10:27 PM
jkc213
For Sale - Wheels / Tires
19
Aug 13, 2011 11:01 PM
varner88
Nov 18, 2009 04:46 AM
varner88
Oct 16, 2009 06:53 PM
