different tire rub problem than ive seen on here!
hey guys, my car is not lowered and i have 18x10 rota grids, with a 20 offset...they are not rubbing on my fenders, they are rubbing on the very front of the fender wall when i turn a bit either way. Are there any tires that will not rub? even when i lower it about an inch?
im on the stock springs right now. not even lowered. its rubbing on the part of the finder liner closest to the front of the car. I was just looking for a brand of tire and size that wouldnt rub there, even if i lowered the car an inch
What size tires do you have? I some people have huge tires that don't rub and some have tires like 255's that do. It would help to know your current tire size.
And +1 on just heating up you fenderliner and adjusting a bit.
Cool I'll probably have to do the heating the fender trick. I'm not sure my current tire size, but they are almost bald anyways so time for new ones. I'm just trying to find out if they are any tires that fit 18x10 +20 rota grids, without any rubbing on the fenders or the fender liners. Anyone had any luck with this?
With a 10 in wide wheel, I would just go with 275s and roll the back and heat up the fenderliner. It will look good. You shouldn't go lower than 265s on a 10 in wheel. I don't know if you can run those wheels without doing some modding to the body atleast a little bit.
