Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Subie wheels
Old Feb 22, 2011 | 07:32 AM
blincoln423's Avatar
Subie wheels
So i was lurking wheeldude.com and found the wheels i want. Unfortunately they are for the subarus, although still 5x114.3 they are at e30 offset, Would running a 15mm spacer and a Hub ring adapter work fine since the wheels hub size is 73 and the x's is 67.1 I believe. I'm looking to get the flush look btw.
Thank you
Old Feb 22, 2011 | 07:41 AM
lancer0220's Avatar
actually most aftermarket wheels come with a center bore size of 73mm or so, just get some hub rings and you will be fine.
i dont know if you will need 15mm spacers or smaller spacers for that flush look, im sure someone will chime in.
also it might help to let others know what size tires you plan on running.
Old Feb 22, 2011 | 07:46 AM
The wheel will be 18x10 and tires for now will be 255/?/18, not sure what size sidewall I should run.?
