Wheel Offset Calculator
While trying to figure out what offset meant, since it seems a lot of people have different explanations. I found this little gem and I figured it's worth everyone checking out.
Taken From site
"Use this calculator to determine the effect of changing your wheel width and offset. First enter your current wheel width and offset. Then enter your new wheel width and offset. Next click the calculate button. It will show the clearance between the inside of the wheel and the strut housing. It will also show how far the outside of the wheel edge will extend or retract. If you reduce the inner clearance too much or push the wheel out too far, the tire might rub or not fit at all. This calculator is for information purposes only and we do not guarantee fitment based on this calculator alone."
I'm not sure if this is a repost but ,I couldn't find this when I searched for it. So here is is:
http://www.1010tires.com/WheelOffsetCalculator.asp
Taken From site
Than you will like this even more:
http://www.rimsntires.com/specs.jsp
Edit:
Site looks a little sketchy though lol
you can just lookup the wheel fitment in the sticky right above this thread
https://www.evolutionm.net/forums/ev...ent-chart.html
evil03
1180
Sep 21, 2021 10:31 PM
lancerman360
91
Apr 22, 2016 03:01 PM
kensuke
92
Apr 12, 2015 10:44 PM
Fourdoor
May 6, 2010 05:30 AM
xtnct
Apr 22, 2010 12:24 PM
