Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Cusco bracing
Old Feb 24, 2012 | 11:33 AM
oftheheavens's Avatar
i have, since first responding to this thread gotten the cusco rear tower strut, rear latter, and rear power members. the back end is night/day difference. i also got the coltspeed front tower bar and it evened out the difference i was looking for to tighten up the car and still not have understeer. i will be replacing bushings next and if i still want to play with suspension i will go ahead and keep adding cusco parts.
note: the rear power member bars do require a little adjusting on the driver side one (at least on the 2010's. and finally i would recommend getting an alignment after those as you have to take off the tow nut to put them on, and this MAY cause an adjustment in tow.
Old Feb 24, 2012 | 01:10 PM
WarmMilk's Avatar
Originally Posted by Noe18
n e one has a before and after video? i would like to know how stiff does the x get
so i know this is old, but what exactly do you think you'll be able to see in a vid in regards to chassis stiffness?
Old Feb 24, 2012 | 07:58 PM
I would guess body roll.
Old Feb 25, 2012 | 02:50 PM
WarmMilk's Avatar
body roll has nothing to do with chassis stiffness
Old Feb 25, 2012 | 04:24 PM
Subi.convert's Avatar
I've got the cusco front sway bar adjustment brackets. They have three settings, soft, stock and hard.
Old Feb 27, 2012 | 01:30 PM
Iowa999's Avatar
Let's argue about this.
I say that it does, albeit indirectly. Stiffer chassis leads to more grip and better feedback to driver. Both of these lead to faster corner speeds. Faster corner speeds leads to more body roll by simple physics.
nyah nyah
Old Feb 27, 2012 | 07:53 PM
WarmMilk's Avatar
review?
Old Feb 27, 2012 | 07:55 PM
WarmMilk's Avatar
nyah nyah
damn it you win again... i was thinking about improvements, so less bodyroll... lame excuse huh...
Old Feb 28, 2012 | 08:49 AM
where did you get the front adjusters from?
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
