How do I get my X to corner?
We are RCE. Glad so many of you like our Subaru products.
Good springs (low and soft is bad), rear swaybar (not too big), alignment, and the WL RCA kit makes a killer all around street set-up. The front swaybar is worth it too.
- Andrew
I'd love to hear people's thoughts on this, especially Andrew. (I could never test what I'm about to write about, since there wasn't an easy fix for the front roll center height of a 2G DSM; maybe you've had the back-to-back, all-else-equal experience that is needed.)
The math says that having a roll center below ground level will actually help with initial turn-in, but will come back and bite you later on in the corner (i.e., it will hurt steady-state handling more than it helped turn-in). Is this a case where the math is misleading or does this match your experience?
This. I was just at Infineon this weekend with a whiteline RSB on medium (stock otherwise). Unforunately my wheels with stickier rubber had a nail in it so I had to go with the crappy DD tires (Sumitomo's). Whoo boy, car's tail end would start to slide way too easily, although it was a good experience to help improve car control.
- andrew
Thankyou everyone for the advice. Looks like springs are the way to go for first suspension mod. My X is my DD so fun factor is the most important thing right now. I traded my 05 STI for the X. The STI had RCE blacks, whiteline sways F&R, and kartboy endlinks. I loved the way it handled, especially on corner exit. Id like to get the EVO close or better without killing comfort. Is there an EVO equivalent to the RCE black springs for STI? Something with a good rate increase without too much drop? I live in Savannah Ga where the roads are rarely smooth.
the main difference I notice in handling between the 2 (I've tracked and autox'd both) is that the evo is looser overall, it behaves more like an rwd car than an awd... My sister is in the same boat, she likes her STi handling better cause it feels more planted. but trust me, loose is faster, you just gotta get used to it.
I have GTWorx and I haven't noticed anything like that... I mean sure they'll bottom out quicker than stock, but I haven't had any issues...
The math is correct in theory...and mostly correct in real life. There are just many, many variables also at play and it is impossible to get a back-to-back, all-else-equal experience. I will say that the understeer can come in very early in the corner....early enough that i can see why people would complain of poor turn-in when the roll center is that low.
I'm not sure if that could be fixed with outrageous spring rates or not, but even if it can you're screwed anytime you're on a less than perfect track, which is almost every track in the US...
front sways are definitely costly to install.
if your on a budget just get springs and a rear sway.
i got the swift spec-R cuz i heard plenty of good things about it but still yet to install it. should have em installed this week or the next. i got the cusco front+rear sways but seriously its way too pricey, if its just the rears maybe try the perrin. they only have a rsb and no front thats why i didnt pick them.
aside from that good tires like wat every1 said. i think the stock ones sux.
i got the continental dws since thats the cheap all season tires cuz im on a budget too. no $$ for the pricey ones let alone a second set of rims for summer/winter
The issue, for me, is planning to run in an autocrossing class above Stock but below SM, which means lowered, but no RCK. We faced exactly this with the 2G DSM: we needed to drop the nose, but couldn't fix the roll center height. The only solution was Chapman's: even taking the lower front motion ratio into account, we ran front wheel rates that were about 1.5 times those in the rear. This got us better grip and less corner-entry push than the standard "logic" of moving weight transfer to the rear. Of course, it also turned the car into a snap-spinning sphincter-constrictor. I really don't want to go through that again, especially when the car is also daily-driven.
Chapman is what I call a "realist."
For sure there are many drawbacks to that approach too.
With regards to front roll center height, it's not exactly that clear cut and perhaps I misspoke before. Roll centers and the roll axis are one way to look at things. It can get a bit more complicated.
Here's a fun read:
http://www.neohio-scca.org/comp_clin...Center2007.pdf
- Andrew
For sure there are many drawbacks to that approach too.With regards to front roll center height, it's not exactly that clear cut and perhaps I misspoke before. Roll centers and the roll axis are one way to look at things. It can get a bit more complicated.
Here's a fun read:
- Andrew
Here's a fun read:
I can't post anything related to the Cheng/Milligan approach (i.e., purposefully low front roll center for turn in) but can say this: they had the fastest time at SCCA Nationals (autocrossing) again this year, so they know what they're doing. I can also say that thinking about the roll axis (even if some say it's imaginary) can be useful. The 2G DSM turned best with a low front RC and a high rear RC. The nickname for this approach to getting those cars to slalom was "stink-bug mode" (tm).
It's really odd. When subbie drivers go evo, they want it to handle like an STi. On the other hand Evos have a hard time driving STis because they don't like the way they handle.
What is it that you liked about your set up? Are you looking for a planted feel? Are you looking for more oversteer?
I'm not familiar with the RCE black springs, but GTWorx and Swift Spec-R springs are your best bets. They have a higher spring rate, and don't have a huge drop. They are all about handling vs the other springs that were more for show imo. Start there, then incrementally upgrade your system when you're looking for another feature.
The 11 GSR, it's only at about 1k miles, and because of break-in I haven't felt it on anything technical, just some sloping fun high speed freeway goodness. I think the thing that throws off my confidence is a very slight amount of body roll, that starts to give the "off-center" feel. It then starts to FREAK me out when I feel the AYC start change the power up as the car starts to induce a little under-steer. It's the same feeling I've felt driving a 2wd pickup in bad rain when the back end starts to push a little when it starts to lose traction...but with the Evo, it's the AYC tracking the car into a neutral feel.
I can't wait to do some suspension mods and go to 265's on the rubber!
