Ohlins Road & Track from CBRD
If you get Tein's make sure it's their the Mono Flex. A monotube damper is, in my opinion, better than a twin tube in most applications.
As far as pricing, Tein's will probably run you around 2k, Ohlins a smidge over 3k.
Wheels are 18x10 with a 25 offset on 265/35/18 tires. I'll measure the ride height tomorrow, since I've made some changes since they were first put on.
Finally went out and measured the ride height. I'm around 25.5" from the ground to the fenders. Slightly different on each corner (although all near 25.5") due to corner balancing the car to get a even cross weight.
In the pictures that were posted though, I believe I was at 25" flat. Had to raise it because I was scrapping too much and honestly felt it was too low for autox.
Can you recommend a particular brand of adjustable end-link? I only needs fronts right now.
PM'd you.
