Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
brake pads
Old Apr 20, 2012 | 11:21 PM
x-boosted's Avatar
brake pads
hey guys,i changed all my brake pads but forgot to put back the oem backing plates.Is it ok without it?
Old Apr 21, 2012 | 10:32 AM
alex3dworld's Avatar
those plates keep the heat from your pads to be transmited to the brake pistons and from there to the entire system. you should also apply a termic paste that should came with the new pads, or buy it at pepboys. those plates also help to apply the force comming from the pistons equally on the pad surface. it's part of the design, would you survive without them?, i would say yes, unless you are thinking to track your car. but you are removing a supporting device from the system. just put them back as soon you have time for it.
Old Apr 21, 2012 | 07:33 PM
x-boosted's Avatar
Ok,thanks for the info
PMPN8EZ
Mar 27, 2016 08:15 AM
Zach S
Oct 15, 2015 07:57 AM
hamflex
May 5, 2011 08:55 PM
2kvette
Oct 24, 2008 11:42 AM
riceball777
Mar 28, 2007 12:28 PM
