Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Spacers?
Old Jul 18, 2012 | 11:17 AM
xTiCkxMYxLaInTx's Avatar
Spacers?
I am currently running 18x9.5 Rota Torques with stock studs for the lugnuts as well as Muteki lugs. They are wrapped in Falken FK452's that are 265/35/18 and lowered on Swift Springs Because of the size of the wheel/tire combination, the rear wheels has a slight negative camber. Also, the rear wheels sit slightly under the fender still. They are not flush with the wheel well (hard to explain). I was thinking about getting some spacers for the rear wheels. Will this help eliminate my problems? Would I need anything else other then spacers? Any help would be greatly appreciated
Old Jul 18, 2012 | 06:19 PM
cubandiaz's Avatar
Whats the offset of the rims? I assume you were going for the "Hella Flush" look? Did you get a alignement after you drop the car on springs?
Old Jul 19, 2012 | 07:41 PM
Offset is +20. I'm not really going for a "hella flush" look. I just want the wheels to be flush with the fender in the rear. And yes, I did get an alignment
Old Jul 20, 2012 | 08:22 AM
ProjectGSX's Avatar
If you want the wheels to sit further away from the center of the car, add spacers.
Old Jul 20, 2012 | 11:30 AM
Thanks
