Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
whiteline vs hotchkis
Old Feb 20, 2013 | 03:15 PM
jhinkle's Avatar
any real noticeable difference here on a rear sway bar for a evo x?
one is in stock and cheaper and the other is a 3 week wait and more expensive.
Old Apr 16, 2013 | 06:47 AM
jhinkle's Avatar
ran the whiteline bar this weekend. works great. I am happy I did not spend the extra money and I am glad I got the smaller diameter bar - it fits nicely and had pleny of stiffness.
Old Apr 24, 2013 | 05:01 AM
denlin68's Avatar
i have whiteline rear sway bar on the evo X, i had hotchkis one on my bmw 330i , both great bars, but whiteline is a solid heavy bar, i think hotchkis one is hollow so it might be a couple of lbs lighter
Old Apr 24, 2013 | 06:20 AM
Iowa999's Avatar
The Whiteline and Hotchkis rear bars are both rather aggressive and, even at their lowest setting, are much stiffer than stock. If you have no plans to upgrade the front bar, I would go with either Works or Perrin (i.e., a 25mm rear bar), instead, as these have a better set of options when the front bar is stock.
Old Apr 26, 2013 | 08:48 AM
jhinkle's Avatar
do you race your car?
i have my whiteline on the most aggressive setting and its still fine on the street.
Old Apr 26, 2013 | 09:11 AM
joseph143's Avatar
Yea but does it kick the *** loose in a corner... Or does it pick up the inside tire because its to aggressive... Tripoding is cool but it shreds tires and you loose an entire tires contact with the road...
Old Apr 26, 2013 | 10:51 AM
Iowa999's Avatar
Not according to my insurance and warranty.
I'm glad that you're happy with your car. I, personally, would rather not drive a car set up that way at high speeds. But I'm glad that you enjoy your car.
Old Apr 26, 2013 | 01:06 PM
N.G.S.'s Avatar
Look into the Eibach sway bar - The softest setting is 7% firmer than stock.
Old Apr 26, 2013 | 01:15 PM
Iowa999's Avatar
I don't run a front bar and the OE rear is often too much.
Old Apr 27, 2013 | 11:57 PM
michael8238's Avatar
are you running on stock end links?
Old May 1, 2013 | 09:04 AM
jhinkle's Avatar
no I upgraded to the whiteline endlinks based on recommendation and prior experience of board members here to avoid a known problem in advance
Old May 11, 2013 | 06:28 PM
Russco's Avatar
I have Hotchkis rear bar with their endlinks as well. Iowa999 is on the money, I run 500lb front 3-way coilovers with 600lb rears and it's on full soft - wish it had a softer setting (that's on R1's at the track). Too much rear bar in my setup with the OEM front bar, going to try the OEM rear bar next time out and see if that gives me more rear-end grip.
Old May 23, 2013 | 09:33 AM
sprisneo's Avatar
using hotchkis and would recommend it.
Old May 24, 2013 | 08:37 AM
Iowa999's Avatar
I would love to hear from someone who has taken a slightly different approach ... lots of front spring with OE front bar; relatively little rear spring and lots of rear bar. If nothing else, the drive home would be nicer.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
