bad clunking over bumps
live in rough part of town. just bought a used evo x with 17000 km on it and it bangs pretty hard over any line or pot hole in the road. is this normal or are shocks and struts already gone on it?
i had the same issue, mine turned out to be a broken rear sway bar link. the bar sheared the threads off of the stud and took the nut off, so the link was just dangling and banging on everything.
Haven't had this experience with the evo but on past vehicles there have been a couple possible reasons.
Could be a ball joint, a sway bar end link or bushing, shock/strut etc... Any fluid leakage? Best bet is to lift that wheel off the ground by the frame and pull/push the tire around a bit and see if you get a clunk somewhere or obvious movement where there shouldn't be any. That might help narrow it down.
Nomad4g63
29
Jan 28, 2008 01:58 AM
