Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
DD Brake Rotor Advice
Old Feb 11, 2014 | 11:17 PM
Roen's Avatar
Preface: I have a separate set of track rotors and pads. These are only going to be used on the street for DD duties.
My pads & rotors are wearing low so I'm in the market to replace them for DD usage only. I will probably switch from stock MR 2 piece to 1 piece in the front for DD duties.
The rear rotors will be replaced with Raybestos AT Rotors (blanks). Can't beat them for $38 a pop from a reputable brake manufacturer.
The front rotors will either be Centric 125 series High Carbon Rotors or (please don't hate me) PowerStop JBR1317XPR Drilled / Slotted Rotors. Let me say that I've always been against the idea of drilled rotors as they'll crack from high temp (track) use. However, these are going to be only used for DD duty.
The funny thing is that the PowerStop rotors are cheaper than the Centric rotors. I'm wondering what people think about this. Is it possible that PowerStop uses cheaper, low quality materials for their rotors? I've never really heard about this company so any advice would be helpful.
For reference, the Centrics are $4 more expensive for the pair and the Raybestos are $12 more expensive for the pair of fronts.
If it matters, I'll mate them with either Porterfield R4-S or Racing Brake ET900 pads.
Old Feb 12, 2014 | 08:29 AM
Johnr352's Avatar
I think it doesn't really matter either way unless you drive very aggressively on the streets. If it were me, I would use the non drilled rotors though, so if I cracked a rotor at the track I would have a spare set (your DD rotors) and not ruin your day...
Old Feb 12, 2014 | 11:13 AM
Roen's Avatar
+1, smart.
Old Feb 12, 2014 | 11:26 AM
grillpt's Avatar
I've had great success with Centric rotors for both street and track. They're all I ever buy.
Old Feb 14, 2014 | 08:02 AM
211Ratsbud's Avatar
Which centric is the higher quality one?
Old Feb 14, 2014 | 12:15 PM
Roen's Avatar
Originally Posted by 211ratsbud
which centric is the higher quality one?
125
Smike
628
Oct 27, 2024 04:39 AM
Smike
63
Apr 29, 2019 07:27 AM
pckiller00
14
May 9, 2016 09:30 AM
