Alignment today. Need help.
I did a bit of research but I didn't find an real answer:
Can someone give me a detailed description on how to adjust camber settings on the front and rear. He botched this up something fierce and it handles like ****.
Swift spec r springs all around, 20mm spacers in the front (waiting for rears to come in)
So for rear camber adjustment, you just turn the bolt with the 'mating marks' (1/8 - 1/2 turn) either slightly counter clockwise or clockwise to adjust negative or positive, correct? Always curious about the rear camber adjustment, haven't needed to play with it yet as mine has fallen into spec each time. But when I get wheels, I will..
There's no other step to it, and it will not strip by simply turning that adjustment bolt head that faces rear?
martinPL
Nov 8, 2015 08:15 PM
FS[Mid-Atlantic]: SSL seats from a 2005
Viegasjuice
Nov 30, 2014 09:23 PM
