Suspension 101?
Suspension 101?
I just purchased a set of coilovers and while I wait for them to arrive I decided to start trying to research suspension info so that I can attempt to set them up properly and I cant really find much. Does anyone have any cool links that might be able to help me out? I want information on things like setting ride height, pre-load, compression, rebound etc and how one influences the other. Any help is greatly appreciated.
What brand did you get? I know a lot of brands have a decient instruction guide for installing and setting a "recommended" height and settings.
I dont want to post a certain setup if thats not the coilovers you have. If you look into the how-to section there are a few members that have posted how-to's for certain models.
http://www.pirate4x4.com/tech/billav...lovers/Part_1/
Above is I think what you are looking for...
Realized thats for lifted trucks, Here is another read from SS
http://www.superstreetonline.com/tec...oilover_works/
However, the thing is you can adjust them to however you like. It is recommended that you get an alignment and I recommend further if you want more out of your coilovers that you corner balance them.
I bought some Eibach Multi-pro R2's. they are rebound and compression adjustable and I have NO idea how to properly dial that in lol. Thanks for the links...I will check them out.
Nice coilovers. I purchased Ohlins myself, and depending on work I can hopefully put them on this month. They have been sitting waiting to be installed for a few months now...
I havent seen too much info for those specific coilovers. In the instructions it should give a "perfered" setting i.e. measurements from top hat to bottom, measurements from bottom coil ring to bottom/top. You could possibly email eibach and let them know your setup and what you plan on doing and they might be able to point you in a good direction.
GTWORX.com
21
Oct 13, 2016 11:04 AM
Lag is Free
Jan 19, 2014 04:47 PM
IGGZ
Jul 5, 2013 02:30 AM
gnulooks
Nov 12, 2004 11:25 PM
