Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
2mm spacer?
Old Apr 7, 2014 | 10:12 AM
Roen's Avatar
2mm spacer?
I've found a 3mm hubcentric spacer for our cars.
Now the question is, has anyone ever heard of a 2mm hubcentric spacer for our cars?
Old Apr 7, 2014 | 01:25 PM
alsong2002's Avatar
why exactly do you need 2mm?
Old Apr 7, 2014 | 08:18 PM
Roen's Avatar
Because I don't want to space it 3mm.
Old Apr 8, 2014 | 04:32 AM
NFSLancerRA's Avatar
Probably not. Most spacers are cut out of readily available stock. I can get 1mm, 1/8" (3mm), and 1/4" (6.3mm) Aluminum plate. I know that 5mm is advertised, too. My guess is that you would pay out the *** for a 2mm spacer, but I could be wrong.
Old Apr 8, 2014 | 04:37 AM
meckert's Avatar
I'm with you, I'm trying to figure out why .040' makes a difference on wheel spacing as well.
Old Apr 8, 2014 | 08:05 AM
Roen's Avatar
Because I want to keep it as close to the caliper as I'm comfortable with and I'm **** about an extra 1mm.
Old Apr 8, 2014 | 11:15 AM
Iowa999's Avatar
If the wheels have a 67.1 centerbore and are designed to be hubcenter (e.g., the OE wheels), then I would not use a 2 or 3 mm spacer. Why not? Because that's 2 or 3 mm less hub inside the centerbore of the wheel. And you want all of it.
If the wheels have a larger centerbore, then you can get thin spacers with a built-in centering ring and have the entire original amount (or more) of hub inside the wheel's centerbore. That's fine.
If the wheels are intended to be lug-centric, then you're fine either way.
Old Apr 8, 2014 | 02:59 PM
I completely understand this. I am really not happy with the way that my current wheels sit. I wanted 18x10.5" ET22, but I settled for ET20. Then, I learned that the Miro wheels won't clear the calipers quite right. On top of that, the barrels are too small to run larger rotors/bigger calipers.
Bottom Line: Pay the extra money to guarantee that your wheels will be what you absolutely want.
Old Apr 9, 2014 | 10:13 PM
Roen's Avatar
2mm spacers are most likely not going to have a centering ring, correct? It's for a 75 centerbore wheel, using 75 to 67.1 hub rings. If the spacer is hubcentric, the centerbore of the spacer should be 67.1 right?
I'm just annoyed that Enkei went with the R-Face on my 10" wheel, even though the 10.5" wheel of the same offset that has the M-Face is offered as a fit for the Evo X.
Old Apr 10, 2014 | 12:32 PM
Iowa999's Avatar
If you search around, there's a place (that I can't remember the name of right now) that will make spacers with built-in hubcentric rings. They are CNC'd from a single piece of stock, so the ring maintains good strength. That would be the safest option for you (by far).
I actually own a set, but they were loaned to someone who has neglected to return them. No use to you, anyway as they were 67.1 to 72.? rings.
Old Apr 10, 2014 | 03:51 PM
Roen's Avatar
If you search around, there's a place (that I can't remember the name of right now) that will make spacers with built-in hubcentric rings. They are CNC'd from a single piece of stock, so the ring maintains good strength. That would be the safest option for you (by far). I actually own a set, but they were loaned to someone who has neglected to return them. No use to you, anyway as they were 67.1 to 72.? rings.
Sweet, thanks!
Old Apr 11, 2014 | 08:43 PM
Roen's Avatar
Adaptec Speedware?
Old Apr 12, 2014 | 06:44 AM
Iowa999's Avatar
Maybe. But I got mine from http://www.motorsport-tech.com/wheel_spacers.html
Old Apr 16, 2014 | 08:54 AM
Roen's Avatar
Ordered my 3mm spacers, thanks!
Luckystryke
For Sale - Wheels / Tires
Aug 8, 2016 06:34 AM
ilviolatorli
Feb 7, 2016 05:54 PM
Martinezusn
May 30, 2014 06:05 PM
07outty
10
Jul 28, 2011 08:59 AM
EVOXMAINE
Jan 29, 2011 08:06 AM
