Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Front sway
Old May 1, 2014 | 10:18 AM
Uscbryan's Avatar
Front sway
Hello,
I'll be having a lot of work to my car in a few weeks. Carbonetics twin clutch, ohlins, replacing all trans, diff and engine bushing with stiffer ones. I currently have a front roll center kit and rear whiteline sway. Shop is telling me a front sway will help a lot. I'm just curious if it will make dialing out understeer more difficult.
Thanks
Old May 1, 2014 | 10:23 AM
Ralliart09er's Avatar
if you go with the whiteline 26mm in front, like mine, its adjustable to 3 different settings so it'll be of help to your taste. What size is your rear one?
Old May 1, 2014 | 10:43 AM
Uscbryan's Avatar
The rear is the biggest one they sell. Forgot the mm. But if I get a front sway and end up tuning in on softest setting wouldn't that defeat the purpose or is the softest still stiffer than stock?
Did you get endlinks with it? For some reason I don't see end links on map's site for the front.
I know it's a ***** to instal. I'm assuming it's easier to adjust?
How do you like it? Feel a difference after installed?
Thanks
Old May 1, 2014 | 11:02 AM
Sev's Avatar
Sev
Rear bar WL sells is 27mm IIRC.
Old May 1, 2014 | 11:13 AM
Uscbryan's Avatar
Well I just spoke to Chad regarding my ohlins and he recommended the Perrin PSRS kit instead of the sway. I was looking at that awhile ago, maybe I'll try that.
Old May 1, 2014 | 11:24 AM
Nagua's Avatar
I have the Whiteline rear. It is 27mm AND also 3 way adjustable. Whatever you do do not buy their end links. Talk about problems.
Old May 1, 2014 | 11:32 AM
Sev's Avatar
Sev
The noise? It's normal.
Old May 1, 2014 | 11:51 AM
Nagua's Avatar
No. No it is not normal. Trust me if you are hearing noises you are probably increasing the hole diameter on the sway bar. I would inspect it just to be sure.
Old May 1, 2014 | 03:22 PM
Sev's Avatar
Sev
I don't have mine installed yet, but I will soon and report back. But from what I've read, slight noise is normal. Either that or improper installation.
Old May 1, 2014 | 08:54 PM
Johnr352's Avatar
Originally Posted by Uscbryan
Hello,
Thanks
Yes. The adjustments will help.
Old May 1, 2014 | 09:45 PM
Nagua's Avatar
What end links are you gonna use? Avoid the Whiteline end links. Very problematic.
Old May 2, 2014 | 06:53 AM
Iowa999's Avatar
Coming up on ten hours, Nagua. Time to warn folks again about them end-links.
Old May 2, 2014 | 07:20 AM
Wish I could find the thread again on where I got my info from when I had decided to do the swaybars. It was saying that on awd you want to have a bigger one in front than the rear, and that id need front end links. I went with the whiteline 26mm front 24mm rear and whiteline front end links. Yes, those end links are universal garbage, steer clear of those. Alot of people I notice say its a pita of an install for the front one. A friend of mine and I who have never done sway bars installed them and when we got done we thought the front wasnt as bad as everyone had preached about. More intimidating than anything when they start chirping about disconnecting the subframe. After we test drove my car, my friend immediately ordered them for his 300zx too. They even do make a difference with a good set of coilovers. Go for it, its worth it
Old May 2, 2014 | 07:22 AM
Sev's Avatar
Sev
Whiteline.
Old May 2, 2014 | 07:37 AM
Uscbryan's Avatar
I have had my whiteline rear sway and endlinks on the car for about 40k miles and no noises.
I'm just wondering if I should add the front.
