Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
rpf1 or 57dr ?
Old May 28, 2014 | 05:11 AM
scott.pa's Avatar
rpf1 or 57dr ?
18x9.5 +15 enkei rpf1
or 18x9.5 +22 gram lights 57dr?
... I do not want to roll or have any issues with fitment. I have stock suspension currently but plan on buying a set of ohlins in the future. Would 18x9.5 +22 be the best size? 265/35/18 tires.
Old Jun 13, 2014 | 12:04 AM
Cris13EvoX's Avatar
I would go with the Gramlights myself, my friend had the RPF's in that size it looked good and he was lowered on Tein coils.
Old Jun 13, 2014 | 08:13 AM
stiggysaurus's Avatar
if you care about performance and unsprung weight def go with rpf1 - the gramlights are actually not that light - over 22lbs IIRC
Old Jun 13, 2014 | 09:08 AM
alsong2002's Avatar
i will go with rpf1.
57dr is a copy cat of te37, if you really like that style, save your money to go with te37.
Old Jun 13, 2014 | 01:59 PM
Jdjones24's Avatar
57dr!
Old Jun 16, 2014 | 12:19 PM
ChrisB's Avatar
Veteran: Air Force
Personally I like the RPF1s. Great, lightweight wheel!
Old Jun 16, 2014 | 12:23 PM
lippy1306's Avatar
RPF1's require fender rolling. Get a set of 57dr's.
Old Jun 16, 2014 | 01:37 PM
KruMsz's Avatar
depends on your goal. if your going looks, get something that is not so played out. performance, rpf1 is good.
Old Jun 16, 2014 | 01:49 PM
R/TErnie's Avatar
18x9.5 RPF1 +38 offset. Run a 25mm spacer up front/5mm spacer rear. Your rear quarters are going to be destroyed by either of the wheels with the offset you've spec'd. +30 to +33 in 9.5" is about the perfect fitment inboard/outboard in the rear. Caliper clearance is your only fight up front, and that is dialed in with a spacer. Lots of room up front. I run 10.5's on factory fenders, so you have room... use it wisely.
Old Jun 16, 2014 | 01:54 PM
KruMsz's Avatar
are you talking about a evo 9 or evo x? cause he has an x.
Old Jun 16, 2014 | 02:20 PM
NFSLancerRA's Avatar
The MiRO wheels that I have are knock-off TE37s. The Rota Grids are knock-off TE37s. The Gramlight 57DR by Rays is as far from a knock-off as you can get.
Old Jun 16, 2014 | 06:27 PM
R/TErnie's Avatar
Originally Posted by krumsz
are you talking about a evo 9 or evo x? Cause he has an x.
bah!
Old Jun 17, 2014 | 04:53 AM
lippy1306's Avatar
Agreed. Rays makes both the Volks and the Gramlights, saying the same company knocks off its' own wheels is silly.
Old Jun 18, 2014 | 10:16 AM
simulatedwood's Avatar
Enkei RS05RR?
Or try the enkei rs05rr in 18 x 9.5 +22. Perfect fitment and only .5 lbs heaver then rpf1s and way stiffer!.
Old Jun 18, 2014 | 07:54 PM
Noize's Avatar
EvoM Administrator
+22 all day. They won't rub with 265/35-18.
Source: I had +15 RPF1, they rubbed. I have +22 TE37SL. They don't rub, don't require rolling.
Tires are PSS.
