Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Work Cr Ultimate (Kiwami)
Old Sep 5, 2014 | 10:17 AM
ayooo_itzme's Avatar
Alright Guys,
Hopefully you guys can give me some advice. I did do a lot of research and had some people tell me this and that but I would like some piece of advice from someone with an Evo X and experience.
Work Emotion Cr Ultimate (Kiwami)
18x10.5 +15
265/35/18
I have Whiteline Lower Control Arms and I know for sure I need a roll in the rear with camber.
I'm trying to get a flushed look, almost like eliminating the wheel gap. I want to know
What is the best suspension to go with?
Springs or Coilovers?
Money is not an issue as you have to pay to play.
I read about RobiSpec KW Coilovers, Ohlins, AMR, etc.
What are your opinions? My goal is to go low, but at the same time looking for the max comfort possible. I don't track haha...
Would you recommend different tire spec as well?
Thanks guys
Old Sep 21, 2014 | 09:18 AM
PSUfan1's Avatar
I have KW V3's on my car and I like them a lot for daily driving. That being said, when I purchased mine they were ~800 cheaper than the Ohlins setup. I got quotes from several vendors and they were in the area of $2600 vs $3400 at the time (about a year ago). I also found someone on the forums that had a new set but was going another direction with his car, so I got another few hundred off. If I was buying new now, it's hard to beat Ohlins with the recent price drops (now under $2800 and include camber plates). I'd personally probably go that route if I were to do it again today.
I'm actually also planning to pick up the same wheels (but in the +22mm fitment) in the next few days to run with 275/35/18 MPSS tires.
Old Sep 21, 2014 | 12:43 PM
michael8238's Avatar
^^^ Ohlins are not much more expensive than KW now, if more expensive at all considering they include the camber plates.
It's really a no brainer if you are in that price range.
Old Sep 23, 2014 | 07:37 PM
johnnybigbooty's Avatar
This is JMO. if this is a daily driver only, why spend 2500 + for coilovers when there's good
coilovers under 2 grand and are rebuildable. Now if your going to do some track time then I
can see the point....or is this just for bragging rights.
R3VOLUTION
Jul 4, 2015 05:39 AM
RavSpec
102
Jun 12, 2015 04:20 AM
Brian's 8
Midwest Region
Apr 23, 2015 06:08 PM
dnizzle
Apr 13, 2015 09:48 PM
Heater55
Jan 26, 2014 11:40 AM
