Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Whiteline RSB + endlink question
Old Oct 10, 2015 | 08:13 PM
isaachunyu's Avatar
Hello!
I was trying to install the Whitline RSB and endlink today, but I have some questions.
1) Any hints/tips how to take out the endlink top bolt? It's so tight....
2) My RSB package doesn't come with the bushing brackets...Is that normal?
Attached Thumbnails Whiteline RSB + endlink question-20151010201228.jpg   Whiteline RSB + endlink question-img_0043.jpg
Old Oct 16, 2015 | 07:11 PM
isaachunyu's Avatar
Just leave a comment for people who encounter the same problems.
1) remove the rear wheel, then you can access the top endlink bolt.
2) the whiteline rsb package doesn't come with the bushing brackets. You have to reuse the OEM one.
Old Oct 18, 2015 | 07:36 PM
Capt. Evo's Avatar
Originally Posted by isaachunyu
Hello!
I apologize if I am stating the obvious, but the bolt has an allen key hole in its center to keep it from turning while you losen the nut attached to the bolt.
Mine did but I ended up using the OEM brackets because I did not like the brackets provided. The slot of those brakets did not give me the impression it had enough surface for the nut to press against it.
RABYRAB
Aug 3, 2013 05:58 PM
vastevo
Feb 4, 2013 05:34 AM
Pr3z
Apr 14, 2011 07:06 PM
MitsuJDM
Sep 24, 2007 05:47 PM
