Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Abs system
Old Feb 28, 2016 | 11:20 AM
Mannymenx's Avatar
Abs system
Hello everyone, I'm new to this so hopefully I can get help. Replaced all struds on my 2008 Evo X gsr. It requires you to take out the hub assembly on the rear ones. Once I was done and put everything back together my abs light came on and my launch control light as well. I checked my for fuses and the sensor connection lines and no damage or anything. Any ideas? What can it be?
Last edited by Mannymenx; Feb 28, 2016 at 11:24 AM. Reason: Pictures are not the ones I uploaded
Old Feb 29, 2016 | 10:51 AM
hoobastnk90's Avatar
most likely a damaged wheel speed sensor, if you go and get the code read they should be able to tell you which one.
Old Feb 29, 2016 | 02:17 PM
Mannymenx's Avatar
Yes I just took it to get it checked, one of my sensors is cracked, long shot but does anyone have a abs sensor???Is my right rear one..
Old Feb 29, 2016 | 02:18 PM
Mannymenx's Avatar
Abs system
doncarbone
14
Jun 17, 2016 02:08 PM
420a-t
Dec 23, 2014 10:17 AM
PoWeRaCeRz
Jan 27, 2004 09:40 PM
