Whiteline KCA414 and Ohlins
So I just finished installing the Whiteline RCK, ALK, and Ohlins coilovers on my evo. Before I take it to the alignment shop I wanted to know if I should install the Whiteline camber bolts (KCA414) on the front. The Ohlins shocks have camber plates, so I dont think its needed.
Could these be used to replace the rear camber bolts?
You shouldn't need a different cam bolt up front if you have the ohlins. You should be able to get -3 degrees static camber with the camber plates and the stock bolts flipped the correct way.
The rear camber adjustment is unrelated to the front. If you want more camber in the rear you will need new arms. But really with normal 1-2 inch drop from stock, you should be able to adjust camber a healthy amount.
roykulokoy
Jul 3, 2014 09:49 PM
GTWORX.com
EvoX 'For Sale' Suspension / Brakes / Handling
54
Jan 21, 2011 10:02 AM
GTWORX.com
Evo 'For Sale' Suspension / Brakes / Handling
108
Jan 7, 2011 09:55 AM
GST Motorsports
52
Jul 22, 2008 11:14 AM
GTWORX.com
54
Dec 14, 2007 08:19 AM
