Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Alignment shop recommendations
Old May 31, 2019 | 12:58 PM
Blue_Lion's Avatar
Hello everyone! This question is mostly geared to those local in so cal. (I’m in the San Fernando Valley). Recently got new tires for my X and I’m looking for a good place for an alignment. If any of you have suggestions I’d really appreciate it. As far as specs go, for daily driving and the occasional back road, I found this while searching for a better all around alignment. Kinda dated information so wanted to see if it would work out. Thanks to all.
“ Front Camber: -2.0+
Front Toe: 0.00
Caster: This isn't adjustable stock, so ~4.1
Rear Camber: -1.5 to -2.0
Rear Toe: 0.00 “
Old May 31, 2019 | 07:28 PM
moladin's Avatar
Unless you have adjustable Rear Control Arms, the Rear Camber on OEM will max out at -1.2 if you want to keep 0 toe. At least that is what my local shop told me.
