Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
spacer
Old Apr 25, 2020 | 08:52 AM
ak47m203's Avatar
spacer
Is the 5mm spacer literally 5mm thickness. I bought a spacer long time and never use it but when I measure it is only 3mm. If I use spacer is the torque specs on lug nuts is the same?
Old Apr 25, 2020 | 05:16 PM
six40's Avatar
Spacers should be what they say. So yes a 5mm should be 5mm. Sounds like you have a 3mm. Basically a shim. I would torque that to 100ft-lbs, you’ll be fine with a 3mm.
bmxking45
Aug 18, 2012 08:29 PM
06redrocket
10
Mar 8, 2011 06:45 PM
Touge Factory
Evo 'For Sale' Wheels / Tires
27
Feb 26, 2010 04:57 PM
JoeyM3
Sep 21, 2008 06:55 PM
