evo x wheel spacers??
anybody running wheel spacers and or what size? safe for DD?????
I'm thinking about "KICS" 10MM WIDE WHEEL SPACERS
and yes on stock rims!!!
If you're looking for wheel spacers you want go at least 15mm (that's what I run.) Most people I see run 20mm and that's what I would have gotten if they them in the style I wanted.
so 20mm no rubbing??
i have my eyes on
http://cgi.ebay.com/ebaymotors/WHEEL...Q5fAccessories and this: http://cgi.ebay.com/ebaymotors/WHEEL...Q5fAccessories ^^ that one says endevour BUT we share the same hubs w/ them so i dont see a problem (besides posible rubbing) |
To op, i would either stick with ichiba or project kics...
20mm is perfect! even on swift too.
and try not to buy those ebay cheap one, it will cost much more if you have anything happened on them. ichiba and project kics is a good choice with is not so expensive. |
Check this post out: Good review and some nice pictures.
https://www.evolutionm.net/forums/ev...tar-specs.html |
does anyone have any information on ADVERSE affects of wheel spacers on suspension geometry?
obviously apart from the longer studs requirement :) |
i have 20mm bolt on spacers and the tires rubbed on the fender wells.
Originally Posted by tephra
(Post 8252795)
(Post 8252795)
obviously apart from the longer studs requirement :) - putting more pressure on the bearings, potentially causing faster wear - scrub radius is changed (changes the feel at low speed mostly) - the front track is changed (wide track = better steady state cornering) - exacerbates issues that are present in a lowered mac strut car (the moment around the pivot of the LCA is increased due to a longer lever) |
Originally Posted by goofygrin
(Post 8261593)
The things that I've seen mentioned with changing the offset of the wheels (and that's what you're effectively doing with spacers are:
