-   Evo X Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-x-tires-wheels-brakes-suspension-259/)
-   -   Can't wait to put these on! (https://www.evolutionm.net/forums/evo-x-tires-wheels-brakes-suspension/491328-cant-wait-put-these.html)
MiStEr GiZmO007 May 9, 2010 01:01 PM
1 Attachment(s)
Pro Racer GN+
18 X 9.5 Offset 38
Color: HMC (Hyper Metallic Chrome)
What you guys think?
hotdog May 9, 2010 01:11 PM
Offset of of 38 is going to look weird, assuming it even clears the brakes.
After an ultra fast lol-google, according to Wheeldude, the Grids at +38 wouldn't fit the X:
The 18x9.5 +38 model will not fit the Evo X. The Rota Grid has a ton of concave and will require a lower offset to clear the front Brembo calipers. We make this model in 18x9.5 +20 fitment specifically for the Evo X
Now, these ain't Grids, but the same answer might apply.
monkey_187 May 9, 2010 01:16 PM
your best bet is to use spacers or send them back and get the right offset
Domolution May 9, 2010 01:17 PM
Looks like you might need some spacers for those. I might be wrong though.
But other than that, they look real nice. :)
ugakirk May 9, 2010 02:31 PM
Yeah offset is too high. Look and see if they have something closer to 20ish.
MiStEr GiZmO007 May 9, 2010 06:16 PM
This is from the %zigen website... 18×9.5J ●12/ ●22/▼38/43
Do you think 22 offset will be good????
●Clears Silvia, Skyline, Fairlady Z, Supra big caliper
▲Clears Impreza OEM 4POT caliper
▲Clears Impreza Brembo caliper
■Clears Lancer Evolution Brembo caliper
▼Clears GTO fitment
jackygor May 9, 2010 06:22 PM
you ll need a 20 mm spacer!
MiStEr GiZmO007 May 9, 2010 06:26 PM
so 38 offset will not fit then ??? cuz they told me it will clear and will fit to my car ! dang now im thinking hard..... cuz i dont want them to ship it then i gotta bring it back !!!!
CatalystGod May 9, 2010 06:44 PM
▼Clears GTO fitment
Its not the calliper you should be worried about in this case. With a higher positive offset, You are basically reducing the gap beween the strut and the wheel. So you might see issues on that front. For an 18X9.5, +20-28 offset is ideal. You can just get a 10-15mm spacer and call it a day. You should be fine. And not to mention, there's the whole sweep radius blah blah blah side to this whole wheel size argument, please don't make me explain. You'll find tonnes of info online about this.
MiStEr GiZmO007 May 9, 2010 06:59 PM
I forgot to mention to you guys that 2008 My Evo X MR is not lowered or drop still stock .
So i want to know and make sure that DO YOU GUYS THINK THAT I WILL BE FINE WITH THIS SET UP 18X9.5 OFFSET 38 WITH BRIDGESTONE RE960 POLE POSITION 245/45/18???
PRO RACERS GN+
mlomker May 9, 2010 07:29 PM
Did you get a killer deal on the +38's or what? You'll certainly improve your odds by going with a 245 tire but why buy wider wheels to run stock tire size? Among those options I would have done +22.
If you use a 10mm spacer then you could run 265's and you come out pretty much flush with the wheel well (I have +28).
http://sphotos.ak.fbcdn.net/hphotos-..._3117330_n.jpg
MiStEr GiZmO007 May 9, 2010 07:35 PM
lol!!! i did .. and my mechanic said that the tires that i have will strech and will fit fine.... So should i go 18x8.5??? come on guys help me out .... 18x8.5 and 18x9.5 is only a inch differents right ????
so i think i should be fine then .... right ??????? :helpme:
Methodical4u May 9, 2010 07:37 PM
don't know anything about offsets... I like the wheels though.
MiStEr GiZmO007 May 9, 2010 07:39 PM
:helpme:
mlomker May 9, 2010 07:39 PM
It'll work. I'd run the spacer. You can always get wider tires next time.
