gotta a question someone please help
Ok so i have an evo 9 and mod wise i have turboxs dp turboxs catback ultimate racing testpipe authority o2 housing and k&n intake and greddy type s bov . The car is boosting to like 24 psi why?? i do not have a boost controller and when it boosts highg like this it hits a boost cut. when i get the boost controller and set it for a set psi will i be ok and also should i get this tuned soon thank you .
With the exhaust components, you have reduced the back pressure, which is causing the boost to spike higher than normal, because there is no direct boost control. The ECU is manipulating the wastegate as if you still have the stock exhaust without realizing you've changed the system. With an MBC, you will be able to regain control of the boost and set it at a normal psi (21psi on 93oct). You should no longer hit boost cut after that. Also, if it isn't already, make sure your BOV is fully-recirculating.
A tune would be great, but is not necessary unless that K&N intake you have is a cone filter. If you have the drop-in panel filter, then no tune is needed, but a tune still would give great power. If you have a K&N cone filter, then you'll need a tune to make the car run properly.
Originally Posted by rjsdxm
i have the k&n filter with the carbon fiber heat shield is that what you meen by cone filter and if so this meens tune right im going to tune anyway but thank you you were very helpful
ok so then what is a good filter and why is it so bad?? and if i get the car tuned will it be ok??
If you do a search for a part and it has lots of "issues", you ought to consider removing it and replacing it with what is suggested in the threads. Then, with a good complement of parts, your future tune will be optimal...
