Clutch,hesitation, and rattling issues!
I have an 03' evo... I had clutch slipping problems and immediately changed the clutch line to the "Russell Stainless Clutch Line" and removed the restricter out of the slave cylinder. Now that didn't fix the problem. I had an Exedy carbon single plate clutch and flywheel installed and now im having some serious rattling problems! im pretty sure its a heat shield though. but which one? But my main concern now is that the clutch is starting to slip again... slightly at high rpms... now when i start to boost, the car will hesitate. It could be the spark plugs? Some say its my BOV some say its my piping! Is this a clutch installation, Vacuum leak, BOV, or None of the above? Whats goin on!!!!!! im lost!! haha
Holy man, you lost me and yourself. Start from where you think the problems is and work backwards. The clutch does rattle, mine does too. I just put a 2900 ACT street disc in and it still rattles. All my heat shield are tight. You BOV could be put in wrong to give you hesitation. The slipping I am not sure about. The clutch could probably use reinstallment. Myabe someone was messed up or left out.....posibly knocked loose. I am not a mechanic, so do not quote me.
Dante`
Dante`
