Clutch Pedal Stuck
Old May 12, 2007 | 10:25 PM
DESERTEAGLE50's Avatar
Clutch Pedal Stuck
I have an 06 Evo9 with 6,000 miles. I have a stock clutch and I was running through the gears pretty hard and the clutch pedal stuck all the way out. It will not push in at all. Any idea what the problem could be?
Old May 13, 2007 | 07:10 AM
EvoJoeIX's Avatar
pressure plate could be broke
check all the lines, see if anything is leakin.
look at your brake fluid resivior and see if the fluid level looks abnormaly low
most likely its something internal, you will most likely need a new clutch
have fun
