HeLp.... Engine Oil all over the back of my Car
Old Nov 3, 2007 | 09:00 PM
acid668's Avatar
Exclamation HeLp.... Engine Oil all over the back of my Car
Guys need your help on this. Was pushing my car on the highway with my frens Teg-R at the back. When we stopped by the side of the road. My friends front hood and windscreen was smeared with engine oil from my exhaust.And also the back of my car my license plate, rear diffuser, booth is covered with engine oil..
What could be the cause of this? A/F ratio? Combustion rate? Or is it my pistons are gone?(My car only has a mileage of 27K i dont think it will be pistons)
Advise advise advise pls fellow frens
Old Nov 3, 2007 | 09:02 PM
EvoDan2004's Avatar
NIIIIIIIIIIIICE. idk man.
Old Nov 3, 2007 | 09:07 PM
gsrboi80's Avatar
If you are seriously blowing oil out of your exhaust like that your rings are smoked and a rebuild is in your near future. Did you way overfill your oil by chance
Old Nov 3, 2007 | 09:14 PM
acid668's Avatar
Nope. i didnt over fill it. But then for my car's mileage of 27K for the piston rings to be gone doesnt make sense. EVO's piston ring is reliable
Thanks for your input
Old Nov 3, 2007 | 09:35 PM
RoadSpike's Avatar
How about turbo oil seals broke?
Pull your LICP and see if oil drains out that should be a good sign its screwed.
Old Nov 3, 2007 | 09:36 PM
acid668's Avatar
Is there a possibility that it is caused by Turbo lag?.
Old Nov 3, 2007 | 09:49 PM
DarkMastyr's Avatar
Sure, about as possible as your apex seals being blown.
Old Nov 3, 2007 | 10:44 PM
Ericy's Avatar
Lol happened to my volvo back in the day, after about 15 minutes I would have to add a quart of oil, was a long ride home, turbo seals were out
Old Nov 4, 2007 | 06:55 AM
acid668's Avatar
Thanks for all your input. I think i can be certain that its the turbo seals that is gone. Anyone knows how much it will cost? And what has to be done? Cos im all new to this turbo scene. Your help is very much appreciated.
Old Nov 4, 2007 | 02:42 PM
edardnaekim's Avatar
Old Nov 4, 2007 | 02:50 PM
JakeTheVIII's Avatar
Old Nov 4, 2007 | 02:53 PM
adv4nced53's Avatar
are you sure it is coming from the exhaust? check the turbo feed and return lines for cracks or leaks. the vortex can get the oil on your bumper or spoiler even if it is coming from under the car.
Old Nov 4, 2007 | 02:57 PM
carluver's Avatar
Hey acid, try midwestevos.com it's a new site so It may take longer to find help, but the Ahole's have not infected it yet.
Old Nov 4, 2007 | 03:21 PM
Jimp23's Avatar
I had the same problem! i blew my headgasket!
Old Nov 4, 2007 | 09:43 PM
barneyb's Avatar
Piston rings can go at any time if you encounter detonation. With that much oil going out the back it should be disappearing from the crankcase. So, is the oil level down on your dipstick?
