Clutch Install Question...
I am trying to remove the throwout bearing through the access hole and am having trouble figuring out if it is actually released or not. How do I know it's out?
Dan
Dan
http://evomoto.com/tech_info.php?tPa...d269ff3b120192
check out #21... it tells you how to do it. i followed that how-to on 2 evo clutches that i did and it went pretty smoothly. good luck. i hope that helps.
I have some coolant on the side of the block under the thermostat housing too. Compression test was good. I think I may be leaking in the same manner you were.
Please tell me what you did to rectify the problem.
Thanks.
Paul
