Clunking..bad axle? wheel bearing? HELP!
Old Feb 4, 2009 | 06:36 PM
BoostKid87's Avatar
i noticed this for the first time about a week ago. i also noticed it happens after a lengthy trip, so im guessing it has to do with heat. i get a clunking noise at low speeds, and it gets worse when the wheel is turned, but at higher speeds...pretty much anything over 10mph i get nothing at all...not sure what this could be. also what are my chances of getting this covered under warranty.
Old Feb 4, 2009 | 07:02 PM
Blast83's Avatar
Make sure wheels are torques down. I just did oil change and drove to work on wheels that I forgot to torque... Sounds like what you are describing. I couldn't figure it out until I got to work and remembered that I put my torque wrench away after putting the transfer case bolts back on.
Edit:
Wheel bearing would make a screeching sound when you turn so it's not that.
Old Feb 4, 2009 | 07:14 PM
BoostKid87's Avatar
Edit:
ill check it tomorrow, but i feel like if it were the lugs, it would do it all the time and not just after a long trip...im talking like 50+ miles...that is the thing that is really throwing me off
Old Feb 4, 2009 | 07:20 PM
Blast83's Avatar
Oh didn't read it that well. Yeah if it were lugs it would be all the time, but worth a check. I really don't know then. You due for a tranny/transfer case fluid change (30K/30months)? Might be the axles, so take it in and hope for the best to see if they'll cover it.
Old Feb 4, 2009 | 08:14 PM
BoostKid87's Avatar
yea i figured tranny fluids were due for a changing...i bought the car 2 months ago at 38k miles, and now am at a little over 39..will def try and see if the dealer will cover it. thanks alot.
if anyone else has any ideas, feel free
Old Feb 6, 2009 | 09:34 AM
red evo8's Avatar
check the two bolts that bolt the strut to the hub, those can cause clunking if not properly torqued to 125 ft, lbs.
Old Feb 6, 2009 | 09:38 AM
thatsMR2u's Avatar
could be transfer case, or i would check things like your ball joints
Old Feb 6, 2009 | 10:03 AM
YeVoLuTiOn's Avatar
I know what your talking about I get the same noise. I hear it the most when I pull into a parking spot.. I'm yet to figure it out. I have a feeling it may be the ball joints or the bushings might be shot. My father thinks it maybe the u-joint. Anybody have any ideas? I'm going to check it out ina few weeks when I replace my awesome oem wheel studs..
Old Feb 25, 2009 | 05:57 PM
EriCS's Avatar
There are a ton of post about this noise on the brake susp forum. I had the same problem but I fixed it I think??? Take your wheels of and clean your spring perches (rocks and debris), grease all bushing with lithium grease, check your strut mounts, loose bolts of course, motormounts.
Old Feb 25, 2009 | 06:20 PM
awdwannabe's Avatar
I would have to say to check your ball joints. Basically to check them remove your front wheels and get a flash light and look behind the rotor at the bottom. At the end of the control arm there will be what looks like a black sack (nothing bad intended) with a rod sticking out of it. That sack is filled with grease and if it ruptures the grease will come out and over time when your turning at low speeds it'll sound like a clunk noise, and will get worse as time goes by.
rick1024
Feb 16, 2012 11:50 AM
Pin2Win
10
Jul 9, 2011 03:48 PM
damstr
30
Jul 23, 2008 10:53 AM
Dr.Sound
Feb 2, 2007 04:50 PM
Ultor
May 21, 2004 09:06 AM
