Wiring question..
Old Apr 22, 2009 | 09:49 AM
F1fan07's Avatar
Wiring question..
I know I know, I need help and already posted in the how to's but it's tricky getting an answer. I'm trying to wire up my Prosport Electronic boost gauge. I can handle everything on the install except specifically where to get power and ground from my IX using the wiring that comes with the gauge. I'd also appreciate suggestions or link to threads I missed on what to use so that I don't wreck my wiring harness. Thanks for the help in advance!!
Old Apr 22, 2009 | 12:48 PM
EJW2202's Avatar
I just did this over the winter on my car also. For the red power wires I used the ignition coil fuse under the steering wheel. There is a diagram in the owners manual that says which fuse is which. I just wrapped the wire around it and plugged it back in. For the ground you'll have to find another grounded wire to tap into or just find a screw bolted to the chassis. I think I used the ground wire from my radio.
