how offten to change spark plugs
Old Jan 22, 2010 | 01:15 AM
vipevo9's Avatar
how offten do you guys srcommended changing sprark plugs. 60K as mostly recommnded?
Old Jan 22, 2010 | 12:26 PM
4RETECH's Avatar
I change mine every 60K. Depends on the plugs you run...
Old Jan 23, 2010 | 02:58 PM
FQ-300's Avatar
60K, no. 6k, yes (at least on an VIII, as I see you have a IX). NGK Coppers every other oil change. Granted they are inexpensive, but offer the best performance (in my experience). Changing the plugs only takes 10-20 minutes tops (including gapping, anti-seize, and grease). Some will scream waste of money, but to each there own. I enjoy it
Old Jan 23, 2010 | 03:02 PM
wizzo 8's Avatar
I change mine with just about every oil change. 3k miles
Old Jan 23, 2010 | 05:41 PM
Mike1's Avatar
That is just overkill and does absolutely nothing for performance. You should never have to replace a plug that has under 50k (a good plug).
Old Jan 23, 2010 | 05:50 PM
wizzo 8's Avatar
It is overkill but I do it anyway. $8 for some plugs is not much on top of the oil change.
Old Jan 24, 2010 | 07:54 AM
k2evo's Avatar
Unfortunately, plugs for the IX cost a lot more than $8.
Old Jan 24, 2010 | 08:04 AM
wizzo 8's Avatar
Yea then I wouldn't change them as often if I had iridium plugs. My car came with iridium plugs and i replaced them after about 18k. I switched to copper plugs now
Old Jan 24, 2010 | 08:59 AM
tweaker41's Avatar
http://www.optionsauto.com/prodinfo.asp?number=ND-IKH24
That's definitely not a lot more than 8$.
Old Jan 24, 2010 | 09:07 AM
06MREvo's Avatar
Damn so is that 9.50 for a set of 4?
Old Jan 24, 2010 | 09:19 AM
tweaker41's Avatar
I wish, it's 9.50 a plug which still isn't that bad. I just buy a couple sets at a time. Her's got an 8 so he can run the cheap copper plugs, I should have bought an 8! lol
Old Jan 24, 2010 | 09:20 AM
06MREvo's Avatar
haha yeah...8s use the same plugs at the 1g & 2g 4g63s did...the cheapest I have bought 4 stock ngk plugs for is $44 shipped...
Old Jan 24, 2010 | 11:44 AM
Bigdawgmotors's Avatar
there is NO need to change your plugs every oil change, unless your running nitro methane or 50lbs of boost...
Old Jan 24, 2010 | 12:55 PM
4RETECH's Avatar
I got BPR8EIX and only change every 60 or so.
Every oil change seems a little rough.
But I guess yes, if you are running a lot boost or meth...
But really get really good plugs and then get coil packs.
Old Jan 24, 2010 | 07:33 PM
k2evo's Avatar
^this
Gotta trust a guy with 190k+ miles on an Evo
