Valve: Vent to atmospehere to reciculating need tune?
Old Mar 5, 2010 | 04:19 AM
kiadaw's Avatar
Hi guys. After so many years at EVolutionm.net. I finally get my evo. Its an 05 IX GSR.
The car valve is set to vent to atmosphere, which I heard is not recommended & I rather do without the "boy racer" hiss sound.
My question will be, should I tune after converting to Reticulation setting?
If so I have an idea to only convert to Recirculating only with other upgrade like turbo, so I only need to tune once.
What do you guys think?
Old Mar 5, 2010 | 04:50 AM
AndyBandy's Avatar
No need for a retune for just the BOV swap unless it was leaking or something. If it's just the difference between VTA and recirc, then you dont need a tune.
Old Mar 5, 2010 | 09:22 AM
20gmr's Avatar
you should be fine. The bov wether its vta or recirc should be closed when you are on the gas. It may change some things a very small amount in the lower load cells, the car should be able to compensate for this though. I recommend pulling the negative terminal for a few mins to force the car to relearn the fuel trims without the stallamatic 2000 on there.
Old Mar 6, 2010 | 01:40 AM
kiadaw's Avatar
Thanks alot guys.
Old Mar 6, 2010 | 03:14 AM
chaotichoax's Avatar
btw it's a 06 not a 05 if it's a ix
