new evo owner has a question about o2 sensor
Old May 6, 2010 | 04:29 PM
shrty10135's Avatar
I have code P0037 coming up which is Bank 1 sensor 2 o2 sensor (heated) i ordered a mechanical cel fix since i have no cats (ams tbe) will this fix it ? and which on is this sensor so when i recieve my mechanical cel o2 fix.
Old May 6, 2010 | 04:36 PM
erald01's Avatar
there is only 2 o2 sensors in our cars, one on the o2 hosing ad one on the cat, so sensor 2 is the one on the cat
Old May 6, 2010 | 04:40 PM
Genesis8's Avatar
Yes it will fix it and it goes on after the test pipe since your not running a cat.
Old May 6, 2010 | 04:55 PM
shrty10135's Avatar
oh ok thank you and after i am done should i clear the code of do you think it should go out?
Old May 6, 2010 | 07:32 PM
white_evo27's Avatar
i would clear it... i get misfire codes every now and then, the easiest way is to take the battery off for about 10min and hook it back up... clears my codes everytime... hope this helps!
Old May 7, 2010 | 03:55 AM
shrty10135's Avatar
thanks =)
Old May 8, 2010 | 07:17 PM
shrty10135's Avatar
after the turbo there is one o2 sensor that u can see looking down into engine bay, when i looked under the car there was 2 on the midpipe one on the driver side farther up (right after clamp) and then one about a foot back in the middle on the midpipe on the passanger side which one is bank 1 senor 2 i need someone to kinda show me on a diagram or explain
Old May 8, 2010 | 07:36 PM
Cruza's Avatar
Do you have a wideband? There supposed to only have 2, 1 on the turbo outlet and one right after cat./test pipe.
Old May 8, 2010 | 07:41 PM
shrty10135's Avatar
i have a aem wideband i guess i gotta figure out witch is for wideband.
Old May 8, 2010 | 07:43 PM
Q8_EVO's Avatar
p0137
Old May 8, 2010 | 07:46 PM
shrty10135's Avatar
^ what?
Old May 8, 2010 | 07:50 PM
Q8_EVO's Avatar
IM trowing the same code, P0137, rear O2 sensor. AMS TBE, Catless. it just started throwing it 2 weeks ago, after 3 years of being on the same setup.
so im guessing my O2 rear is done.
Old May 8, 2010 | 07:55 PM
Cruza's Avatar
cel fix doesnt go on the wideband so when you figure out which is the wideband put the cel fix on the other o2
Old May 8, 2010 | 07:57 PM
shrty10135's Avatar
mine is p0037 and yes i no not to put it on the wideband
Old May 10, 2010 | 03:31 PM
shrty10135's Avatar
i put the mechanical cel fix on the o2 sensor on the passangher side, in the middle of the car, and reset code and it stayed off but when you shut the car and turn it back on like 5 minutes in the cel will turn back on. and the only other o2 sensor i see is the one right under the drivers side but thats for my aem wideband and the other one is right past the turbo if you looking down into your engine bay. its bank 1 sensor 2 HELP
