How much power can these mods give???
Anyone know how much whp would the following setup get:
TBE, intake or drop in filter, plus a reflash.
I just want estimate since brands will vary. Is this good for anywhere near 350awhp?
it also depends on if it's an Evo 8 or 9. The Evo 9 comes stock with a little bigger cams than the 8's do stock, so they can put out more power generally with basic mods. and a flash.
If it's an Evo 8 to reach 350 on 93 octane you'll need a upgraded fuel pump, tbe, intake, boost controller, and some smaller cams like HKS 272's, and at 23-25psi with a tune you should be there easily.
If it's a Evo 9 basically the same thing but without cams you should be able to squeeze 350 out of it around the same boost level.
well if you get tuned in the bay area with those mods at gst or fftec your probably looking at 280-295whp
for 350whp ish you need to go e85 on stock turbo. Even with a good set of kelford 272's with those mods on 91 you'll be lucky to crack 330
Im not a greedy person. 350whp is enough for me as a daily driver. Tested out a modded 911 turbo the other day, and it was kind of scary for me. It hits over 100mph like nothing.
I got up to 160mph on my bike at the track and it doesnt scare me.
