actuator adjustment problems**
Old Jun 8, 2010 | 12:04 PM
tbryant0226's Avatar
i recently replaced my actuator with a forged one and instead i put the oem back on. But now im having boosting problems. The little "lever" that the actuator connects to(hole at the end of the rod), is not in line with the hole. I think the turbo boosts when the lever is down. So my question is do i need to keep the lever up or down when i connect it to the rod on the actuator. thx everyone
Old Jun 8, 2010 | 12:18 PM
cfdfireman1's Avatar
the actuator pushes to open, you want it closed when the car is off.
Old Jun 8, 2010 | 12:24 PM
EvoFredo's Avatar
the lever prob wont be inline. just make sure the lever is closed meaning all the way down. if the hole on the actuator is close to the lever you should be able to pull on the rod and it will stretch so that you can slip the hole over the lever. look up FP actuator preload. hope this helps
Old Jun 8, 2010 | 01:57 PM
twista's Avatar
http://store.forcedperformance.net/m...td-setting.mpg
Old Jun 8, 2010 | 02:24 PM
thanks "twista" and everyone. I didn't know what was the setting of the preload. It seems like my wastegate wants to be a Pitah.. well thx again evo forums
Old Jun 9, 2010 | 10:48 AM
Another way to push the rod further out is to put pressure into the actuator nozzle and pump approximately 10-15 psi and it will start going out, then you can get the perfect fit to attatch to the lever. But is there a way I could push it back further in Instead of outwards?
Old Jun 30, 2010 | 06:47 AM
the thing is spring loaded and goes all the way to the stop on it's own. if you need more adjustment you could bend the rod a bit but there should be no need.
