Need Help With Lights!
Old Oct 15, 2012 | 04:17 PM
CeeWhizzle's Avatar
So, I live in Canada land and in the province that I am in, it is a regulation to have DRL's and Night running marker lights. I am currently trying to figure out how to wire my signal lights so they can act as a signal light and side marker. I have heard that it is possible to be done and that it is rather easy.
In the Evo 4, there is the little low beam light that comes on when you turn the knob on the light switch to activate interior lights. The light has 2 wires going into it which is a Negative (Black) and Positive (Green w/ Black stripe). I tried splicing my signal lights positive wire into the low beams positive wire and it made my signal light stay on when I turn the low beams on (Which is what I need).. however it does not turn off or blink when I use the signal light.
Do I need to ground the signal light as well? Or is there another way?
I also tried the headlight with the DRL module and still the same issue..
Any help with this A.S.A.P would be much appriciated!
Old Oct 16, 2012 | 10:58 AM
CeeWhizzle's Avatar
No one knows anything on this? Basically what I am needing to do is converting the front signal lights to front parking light/blinkers.
eddielmc
16
Jun 7, 2019 05:56 AM
mlouis
Feb 4, 2015 10:27 AM
Uryelowducky
Jun 13, 2013 11:51 PM
yitzac1990
Lancer Troubleshooting
Jan 2, 2010 10:03 PM
