Air/Fuel Gauges?
Air/Fuel Gauges?
I want to put 3 gauges on the A-pillar. Boost, EGT, and Air/Fuel ratio. I noticed that Defi makes all three in the D-series gauges. Is their a/f gauge any good or should I just go with the greddy UEGO for that one and be a bit mismatched?
I ordered the Autometer triple A-pillar pod with the tweeter cutout so I can fit 3 gauges that are 52mm.
if youre spending that kind of money on gauges I would make sure they match, although personally I would go with a oil pressure gauge over an air-fuel gauge.
Most turbo timers have an air-fuel gauge built in....I would prefer that over the air-fuel gauge I have now. Best of luck and nice choise in color!
Theres no need to have both and A/F and an EGT gauge. Just use one or the other, I would trust an EGT gauge over those cheapo A/F gauges that use the stock o2 sensor. If you want a true A/F gauge, get wideband, or just stick with the EGT.
Defi makes really good gauges.
The three gauges I would go with are boost, EGT or wideband A/F and oil pressure
I may eventually put another three gauges over in the center console where the stock radio goes. Probably oil pressure, oil temp, and fuel pressure.
As far as the A/F gauge, I have every intention of using a wideband gauge. I couldn't find for sure if the Defi gauge is wideband or not. The other two im looking at are the AEM UEGO or the greddy (if I can get it with red illumination)
Just me 2c,
Later
Just FYI, the Greddy A/F gauge uses a narrowband o2 sensor. I had one on my GSX and it read just as innaccurately as the stock narrowband. Don't get it if you want to use it as a tuning tool.
