I need advice. EVO still has stock clutch,belts,ect at 80,000 miles. Buy it?
I’m thinking of getting this EVO but it still has a stock clutch, belts, ect and has 80,000 miles on it. It’s a 2006 EVO 9 MR that is totally stock and 1 owner. Very clean inside and out. I did a carfax report and the last recorded service was at 20,000 miles. Says he always kept up with the oil changes, and has changed trany/diff fluids. I’m going to test drive it on Tuesday. He wants $17,900 but I think that is a bit much. What do you guys think? I normally couldn’t afford an EVO 9 but this one is closer to my price range. Do you think it’s worth it, or will I end up spending another 5K on service? Should I just try for an EVO 8 with fewer miles? Thanks for any advice you can give me.
well first off I'm surprised that clutch lasted as long as it did, usually when people drive rough the first to go is the clutch, plus around 60k he should have done a good tune up like timing belt and stuff, idk if he took care of it or not,
but try and see if he had any maintance records that he can show you, might be tough cause I don't keep records like that since I do my own work, best thing to do is just test drive it like you said, and get a good idea of what condition the car is in, then from there negotiate the best price, with the economy the way it is right now its bargain time lol |
That's pretty cheap. 17k for an evo IX MR...
The maintenence isn't that big of a deal if you know how to do it. Otherwise, it will cost you. The 60k service is mainly t-belt, balance shaft belt, water pump and gasket, etc. Probably needs a full fluid change and the clutch will go out soon enough. Still 17k for an evo 9 in good shape is a great deal. |
I got it! I now own a white 2006 EVO 9 MR. I had now idea how much fun it is to own/drive an EVO. It goes through gas faster than I expected and servicing it is very expensive, along with insurance, but its all worth it. Have only owned Toyotas in the past but I am now a :mitsu: man. Im glad to be part of the EVO community and thank all of you for the info now and in the future.
--- ALEX |
congrats and post pics!
congrats! hope you enjoy it and be safe! btw post pics
Thanks for the support. I gonna buy a new camera tomorrow and will post some pics.
Just some good advise I would suggest changing all fluids and belts on the car.
yea do a real good once over maintance and start looking into an aftermarket clutch
Originally Posted by JakeTheVIII
(Post 7096261)
The maintenence isn't that big of a deal if you know how to do it. Otherwise, it will cost you. The 60k service is mainly t-belt, balance shaft belt, water pump and gasket, etc. Probably needs a full fluid change and the clutch will go out soon enough. Still 17k for an evo 9 in good shape is a great deal. congrats on the purchase. first thing you need to do is get that timing belt taken care of. i'd make sure all the fluids are fresh by just doing it myself. it doesn't take long to flush the tranny, diffs, and ACD. the fluids aren't that expensive either (because you get like a gallon of each, plenty to do multiple flushes.) it's a lot cheaper if you can do it yourself because the dealership will want to charge an assload of money for even the smallest things. also look at replacing the spark plugs, engine oil, air filter. normal maintenance stuff. i just finished with the 120k maintenance stuff on my 06 EVO IX MR. keep'em up and they'll run forever. it's also not weird to see 80k out of a stock clutch. i got 70k out of mine with me autocrossing, launching, racing every chance i got. i actually got less life, 50k miles, out of the Exedy stage 1 i replaced it with. i'm on an ACT HDSS now, so it's all good. |
you can do a certified-checkup from mitsubishi, that may be a costly option though.
Service records for oil changes & fluid changes are hard to come by because many people do it thereselves. Congrats!! Even tuner shops change fluids for cheaper than factory. Do it every 20k miles or so.
I have my evo serviced(with records) at the dealer, because I can:)
Was wondering why Mitsubishi has the timing belt interval at 60K? Is it required prematurely to prevent dumb owners from destroying their cars?
Originally Posted by abdizzle
(Post 7115514)
