**NEW** Greddy Profec Boost Controller at Extreme PSI
The new PRofec is compact, powerful and easy to use. The large OLED Display, with the simple two-button / rotary-dial control, make for intuitive operation. An ultra slim controller can display in digital, bar-graph, or graphical modes and can be rotated 180 degree for installation with the included adjustable mount or flush mounted. By separating the display and control unit in the driver’s compartment, from the engine compartment-mounted, waterproof, sensor unit, it makes installation straightforward. Only one thin harness is required to be routed through the firewall. The combination of the new 300kPa (43.5psi) integrated pressure sensor, the more compact solenoid valve and faster ECU processer, provide quicker response and the most stable boost curves yet. The PRofec also maintains popular features like, Lo, Hi, Scramble boost presets, last-boost display, peak-hold recall, warning alert and safety limiter. The next evolution of the GReddy PRofec line of electronic boost controllers is here!
Notes:
- Color OLED Display
- Built in Boost gauge (kPa or PSI)
- 3 display types - Numeric, Bar Graph, & Map Graph
- Intuitive Control Screen and Dial control
- 2 preset setting, LO & HI, with 3rd timed Scramble boost setting
- (Lo. & Hi.) Set % - to increase boost (higer number, higher the boost over base boost level)
- Gain % - wastegate response adjustment
- Start Boost - inital boost response adjustment
- Warning point, warning limiter, peak-hold/Last boost
- Compatiable with both actuator style and external wastegate style turbo systems
- Revised compact boost solenoid
- Separated Display/Control Unit and Sensor Unit, for easy install
- Intergrated 300kPa (43.5psi) - high performance boost pressure sensor within the Sensor Unit
- Includes adjustable mounting bracket
Size: 89 x 36.5 x 22.8mm
Click here to buy!
Notes:
Click here to buy!
Thanks,
Tony
www.ExtremePSI.com
1-800-PSI-4502
215-244-4295
sales@extremepsi.com
extremepsi
EvoX 'For Sale' Electronics / Lighting / Audio
Aug 12, 2012 06:30 PM
