The Grimmspeed Electronic Boost Controller for 2010-2015 Evo
Want an easy plug and play boost controller for your car. Well Grimmspeed has the answer. The Grimmspeed Boost Controller Solenoid was designed to work with your factory ECU and capable of producing the same power out put as the factory system but it flows much faster and better. Though this item is still does require tuning, it plugs in easy with no need to modify, splice, or solder anything. It just bolts right in and its ready for fun. This set up is fully reversable so it is very easy to return the car back to stock. Grimmspeeds engineers also made sure to design the product to be small and clean, including high quality low profile hose fittings for secure fitment. Help give your Evo the fast response and better flow than any other valve out there.
