**AMS PRODUCT RELEASE** EVO X Sleeved Block
Old Jan 9, 2009 | 01:30 PM
AutoMotoSports's Avatar
AMS EVO X Sleeved Cylinder block
AMS is proud to announce the release of our new engine program for the EVO X. At the core of this program is our new iron ductile sleeved 4B11 shortblock. In conjunction with ERL PERFORMANCE we are now able to provide a much stronger building block for those looking to run some serious power through the 4B11.
Each AMS block starts with a stock 4B11 core. First the block is machined down until the OEM cylinder liners are no more. During this process precise measurements are taken to ensure that there is no structural disruption of the cylinder block. After removing all of the necessary material and machining a step at the top of the bore a final inspection is done to ensure no block distortion. From here ERL then installs proprietary ductile iron sleeves. The sleeves are pressed into the block to sit on top of the machined step. This ensures they will not sink during engine operation. Once in place the new sleeves are machined a few thousands above the rest of the deck surface. This acts much in the way an O-ring does on a closed deck block and allows for a tighter sealing surface between the block, head gasket and head. From here each block is cross hatched and gets its customer chosen final bore size. One of the last steps involves installing a set of AMS spec main studs and align honing the main journals to allow for perfect fitment. Align honing is crucial as it ensures everything lines up correctly even after the machining process.
As you can see it’s a pretty involved process but when it’s all said and done you have yourself a pretty stout shortblock capable of taking a great deal of HP.
The cost for this service is $1895.00 and it gets you everything you see above.
If you do not wish to send in a core to have machined then there will be an additional $1534.00 for a new OEM 4B11 block. You are also given the option of choosing any bore size between 86mm and 88mm based on your needs.
We will be offering built short blocks in the future but for those Do-It-Yourself guys out there we thought it would be a beneficial to offer the possibility of choosing your own internals.
Please feel free to ask any questions that you may have. Our engine builder Tim will be monitoring this thread to field any questions on this particular part. Thank you and enjoy the pictures!
Eric
Old Jan 10, 2009 | 08:39 AM
supersilverMR's Avatar
WOW... I want one!!
How much will the complete long-blocks be?
Thanks, Tim
Tray@Forged
EvoX 'For Sale' Engine Internals and Drivetrain
Feb 11, 2016 08:15 PM
RichK@AMS
Jun 2, 2010 12:14 AM
AutoMotoSports
Automotosports - Illinois
61
Mar 20, 2009 11:34 PM
Tim@AMSperformance
Jan 14, 2009 04:08 PM
AutoMotoSports
Dec 13, 2008 07:27 AM
