SSP Titan Series Track Packages !!
SSP Titan Series Stage 1 Track Package
Hands down, the most comprehensive EVO X MR Transmission cooling systems currently on the market today. Track tested and proven to drop transmission fluid temps in excess of 40 degrees under racing conditions. This kit is designed for the budget conscious entry level racer. This will ensure you'll be able to complete your sessions without the dreaded slow down message.If you want to stay out of the red, and on the track....look no further!
Kit includes everything needed for complete install:
Package Includes:
SSP Front Mount Transmission Cooler
SSP Stealth Black High Flow Mechanical Oil pump
SSP Pro Gold Transmission Fluid (8 liters)
All necessary lines and mounting hardware
New SST Stainless Reusable Filter
NEW SST Transmission Cooler (New updates allow for use on all SST and Ralliart models 2008-2013)
Complete install instructions included
Our Price - $ 1,659.00
http://www.sspperformance.com/produc...track-package/
SSP Titan Series Stage 2 Track Package
This is for the more serious track car, and upgraded stock location turbo application. The stage 2 kit is rated at 500 hp, but has been track tested for over 2 years on our own 540 whp Time Attack X MR with zero failures, and NO slow down warnings!Hands down the most affordable track tested, dyno proven SST package on the market today.
New Updates to this product:
New 3.0gpm Stealth Black Gear Pump New Lightweight Starlight Black Braided Lines
Updated Low Profile Transmission Fitting for 2010+ models
Complete Package Includes the Following:
1) SSP New Lifetime reusable SST Filter
1) SSP Pro Series Transmission Cooler
1) SSP Stealth Black Mechanical Oil pump
1) SSP Pro Gold Transmission Fluid (8 liters)
1) SSP Pro Series 500HP Clutch Package (8 pack)
1) Setrab cooler and Spal/shroud fan assembly
1) SSP High capacity oil pump assembly
2) 22mm to 14mm reducer fittings
2) 14mm to -6AN male fittings
2) 14mm x 1.5 banjo bolts
4) Copper washers
1) Cooler assembly mounting template
3) Pre-made -6AN with AN swivel fittings
2) Pump with -6AN fittings installed
1) Power wire/fuse holder
1) 30 amp fuse
4) 6mm x 1.25 x 16mm bolts
4) 6mm x 1.5 Teflon locking nuts
4) Self-tapping pump mounting screws
2) -6AN to 16mm transmission adapters (steel)
6) Zip ties
Our Price - $ 2,899.00
SSP Titan Series Stage 3 Track Package
This is for the more serious track car, and upgraded stock location turbo application. The stage 3 kit is rated at 500 hp, but has been track tested for over 2 years on the 540 whp SSP Time Attack X MR with zero failures, and NO slow down warnings.
Complete Package:
SSP Billet Aluminum Transmission Pan (6061)
SSP Viton Transmission Seal Package
SSP Lifetime reusable SST filter
4) Copper washers
1) 30 amp fuse
6) Zip ties
*Complete install instructions included
Our Price - $4,299.00 [/FONT][/SIZE]
http://www.sspperformance.com/produc...x-sst-package/
SSP Titan Series Stage 4 Evo X SST Package
SSP Titan 4 package includes our new high performance 600 hp clutch package
Complete Package Includes:
SSP Pro Series 600HP Clutch Package (10 pack)
SSP New Stainless reusable filter
4) Copper washers
1) 30 amp fuse
6) Zip ties
Our Price $4,599.00
SSP Titan Series Stage 5 Evo X SST Package
SSP Titan 5 package includes our new high performance 600 hp clutch package and utilizes the latest in billet flywheel technology.
New SSP Billet Aluminum Flywheel (5.7 lbs/2.6kg)
SSP Billet Aluminum Flywheel (5.7lbs, 2.6kg)
4) Copper washers
1) 30 amp fuse
6) Zip ties
* Complete Instal instructions included
Our Price - $4,999.00
Package Includes:
4) Copper washers
1) 30 amp fuse
6) Zip ties
Complete Package:
4) Copper washers
1) 30 amp fuse
6) Zip ties
4) Copper washers
1) 30 amp fuse
6) Zip ties
Our Price $4,599.00
4) Copper washers
1) 30 amp fuse
6) Zip ties
In stock and ready to ship, call your Authorized SSP Dealer for best pricing.
http://www.sspperformance.com/sub-ca...sion-packages/
In stock and ready to ship. Contact your Authorized SSP Dealer for best pricing.
Please follow the link below for the complete list of Authorized Dealers and Certified Install shops Worldwide.
http://www.sspperformance.com/content/dealers/
Package Includes:
4) Copper washers
1) 30 amp fuse
6) Zip ties
Complete Package:
4) Copper washers
1) 30 amp fuse
6) Zip ties
4) Copper washers
1) 30 amp fuse
6) Zip ties
Our Price $4,599.00
4) Copper washers
1) 30 amp fuse
6) Zip ties
Package Includes:
4) Copper washers
1) 30 amp fuse
6) Zip ties
Complete Package:
4) Copper washers
1) 30 amp fuse
6) Zip ties
4) Copper washers
1) 30 amp fuse
6) Zip ties
Our Price $4,599.00
4) Copper washers
1) 30 amp fuse
6) Zip ties
