**MEGA THREAD** Clutches| Injectors | Cams | Pistons | Rods | Mounts | Power Packages
Old Jul 1, 2012 | 05:26 PM
JBAutosports's Avatar
Here at JB Autosports we know how important it is to have your car back on the road along with that awesome feel only an AWD launch can provide. It's pretty hard to get that sub 1.6 60ft time, or perfect autocross start with a slipping clutch. We also understand the need for speed so we have the parts on hand to get your car back to kicking ***. Pistons, Rods, Cams, Injectors, Fuel Pumps, and so much more. Check out the items below and as always PM us for the special EvoM Forums price.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
ACT
The entire line of ACT is available. ACT designs each part for a high standard of performance. There are no shortcuts taken on the ACT road. Every design has been evaluated for benefits and tradeoffs. Clamp load, friction, pedal feel, working range and other characteristics are carefully tested and assessed. ACT offers the best combination to achieve the maximum performance. No gimmicks or misleading advertisements – just plain and simple engineering and calculated results.
ACT
Clutchmasters
The entire line of ClutchMasters is available. The FX100 to the FX500 and even their extremely affordable Twin Disc!
Clutch Masters
Clutch Masters Aluminum Flywheel - 12LBS
Exedy
For high-powered applications EXEDY offers Multi plate clutches. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Exedy Single, Twin, or even Triple available.
Comp Clutch
Competition Clutch brings to their customers the finest materials, workmanship, and the best customer service in the industry. We offer higher clamping force, stronger disc designs, and uncompromised satisfaction, all at the most competitive pricing in the industry. Stage 1 through Stage 5 available. We run their Stage 4 in our Sponsored Evo 9 MR.
Comp Clutch Kits
Comp Clutch Flywheel - 11LBS
SPEC Clutch
SPEC Clutches and Flywheels are manufactured on-site using the most advanced methods under the strictest tolerances. We wouldn’t have it any other way. Our commitment to making the very finest parts is at the core of what we stand for as a company. Don’t accept anything less. Stage 1 all the way up to their Twin Disc.
SPEC Clutch Kits Stage 1, 2, 3, 3+, 4 or TWIN Disc!
SPEC Flywheel
Fidanza
Fidanza Aluminum Flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight.
Fidanza Flywheel
FUEL
Deatschwerks DW65C
Introducing the first high flow, compact, 65mm pump. This is a DIRECT OEM replacement! No cutting, no grinding, just some simple hand tools required!
Compact 65mm body for OE fitment
Flows 265 litres per hour
Available with and without mounting clips
Ethanol compatible
3-year no-fault warranty
Quiet and reliable turbine impeller
DW65C
Injectors in 850cc, 1000cc, 1300cc and ethanol crazy 2200cc.
Injector Dynamics
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them to within 1%, in sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths.
Available in 850cc, 1000cc, and 2000cc
Agency Power
Agency Power has released their new fuel rail. This fuel rail is a direct replacement for the factory unit. The CNC machined piece is anodized in Agency Power Red. It fits with the stock fuel pressure regulator and fittings and can be set up to work with aftermarket units as well. The fuel rail also has a location to put an aftermarket fuel pressure gauge with no modification.
Why is this Agency Power Fuel Rail better then stock? Well, the AP fuel rail has a wider diameter for fuel flow then stock. As well, the AP rail is designed to fit larger injectors such as Blitz, RC, and other common brands. When upgrading to a larger turbo set up or needing to upgrade your fuel system, the AP rail will accommodate your needs. While keeping stock fitment and performance when additional fuel is not needed, the fuel rail is also a great dress up piece.
Cosworth
The Cosworth High Volume Fuel Rail Kit for the Mitsubishi EVO X features a machined from solid, hard anodized aluminum fuel rail with o-ringed fittings and a pre-shaped inlet pipe. The Cosworth High Volume Fuel Rail Kit can be used with original or various aftermarket injectors and PRV's. Direct fit replacement- includes all necessary components for a complete bolt-on installation. Designed with expansion in mind, facilitating installation of custom fuel systems including AN fuel lines and remote mounted fuel pressure regulators. "Full-flow" bore will support upwards of 600hp worth of fueling.
Hard anodized finish is methanol compatible.
Cosworth Fuel Rail
NGK Spark Plugs $50 + Shipping
These are the exact same plugs that come in the car from the factory minus the Mitsubishi box. Part# ILKR8E6 . Regain robbed MPG's and HP by keeping your plugs changed at regular intervals. Evo X Spark Plugs.
NGK ILKR8E6
CAMS / SPRINGS / RETAINERS
Cosworth MX1 Cams
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs are the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our cams are profiled to increase boost response thereby increasing engine torque and power and are fully compatible with our CNC Ported Big Valve Cylinder Heads.
MX1 Cams
Kelford
Kelford RaceCams are finely ground to precision specifications. We are well practised in the skills of fine tuning a precision camshaft, we have been welding and re-profiling these cams for so long, finally we are offering cast billets. We have hundreds of grinds for camshafts so we can meet your camshaft needs and do anything you desire.
Kelford Cams
Brian Crower
BC high performance camshafts are ground on state-of-the-art CNC cam grinders to insure accuracy and tolerances to within .02mm. Every BC camshaft profile has been prototyped and dyno tested for proven horsepower results prior to placed into mass production. By grinding cores in high volume, Brian Crower, Inc. is able to pass the cost savings on to the end user. Quality at an affordable price.
Stage 2 and Stage 3 Available
GSC Power Division
Power Division High Performance Billet Camshafts. Engineered to offer the absolute best performance and maintain close to stock drivability characteristics. Power Division has stepped into the market with top quality Billet Cores that will perform with or outperform other camshafts on the market. With the wide array of profiles there is a combination to fit your needs. From basic bolt-ons to fully built engines naturally aspired or Turbo Charged. Power Division offers the setup to suit your needs. All the camshafts provide power across the RPM band and can support extreme race engine conditions due to their superb quality. Why run the others, when you can run the BEST!
Stage 1 and Stage 2 Available
Brian Crower
Brian Crower valve spring and titanium retainers kits are system matched to work in unison to deliver better valve control at extended rpm’s and allow for greater lift camshafts for added performance and reliability.
Springs and TI Retainers
GSC Power Division
GSC Power-Division Beehive springs feature some of the most impressive manufacturing techniques in the industry. Our beehive spring uses an ovate wire which utilizes advanced material heat treatment methods for superior load loss capabilities. What this means to you is our spring has the highest level of spring load retention while still maintaining good fatigue threw out the life of the spring. Only the best materials go into the GSC Power-Division Beehive valve spring. Each batch is scrutinized for tensile strength properties, ductility, inclusion content, and fatigue toughness.
BSC Beehive
Pistons
We have OEM and aftermarket solutions available!
OEM, WISECO, MAHLE, JE, SRP, CP, and more...
Rods
OEM, Brian Crower, MAHLE, Carrillo, Cosworth, and more...
Old Jul 3, 2012 | 06:59 AM
Bump, send us those PMs!
Old Jul 4, 2012 | 07:11 AM
Have a safe 4th everyone!
Old Jul 7, 2012 | 01:19 PM
Bump! Have a great weekend guys and gals.
Old Jul 9, 2012 | 05:01 PM
Check us out at
http://jbautosports.com
Old Jul 10, 2012 | 11:01 AM
Bump it up!
Old Jul 13, 2012 | 05:11 AM
Check us out at
Old Jul 14, 2012 | 05:51 PM
Weekend Bump.
Old Jul 19, 2012 | 05:07 AM
Check us out at
Old Jul 22, 2012 | 05:41 PM
Weekend bump.
Old Jul 24, 2012 | 05:01 AM
ACT Clutch in stock!
Old Jul 26, 2012 | 11:36 AM
FREE SHIPPING On all orders over $250* (*Continental 48 states)
Old Jul 28, 2012 | 05:05 PM
Sat night bump! Have a safe weekend everyone!
Old Jul 31, 2012 | 08:40 PM
ACT in stock ready to go!
Old Aug 4, 2012 | 05:43 PM
Bump!
