Engine Internal Master Thread - Eagle/Wiseco/Manley/Cosworth/Tomei/BC
Did you know that MAP has a package deal section on our website for many of the vehicles we specialize in?
That's right, NOW you can get package discounts on brake kits, clutches, headgasket/ head service parts, engine internals, fuel supply components 24/7 simply by surfing the site!
Select the car below to be taken directly to the package deal section for your vehicle:
EVO 8/9
EVO X
Where you will find package deals like:
AND MORE!
EVO 8/9
EVO X
AND MORE!
MAPerformance not only carries every major wideband on the market, we also guarantee the best price! Whether you like the price of the PLX DM-5 / SM-AFR package or the functionality of the Zeitronix LCD bundle MAPerformance is your one stop shop for wideband oxygen sensor systems!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||
: NateAtMAP|||||
: 1-888-MAPERFORMANCE x 114|||||
: Nate@MAPerformance.com
Get the best pricing and service exclusively from MAP!
Give us a call at 1-888-MAPerformance today to speak with one of our sales specialists for help with your specific needs or start shopping here to browse a selection of our products offerings
MAP 2000cc High Impedence Fuel Injectors w/ PnP Adapters (Mitsubishi Evo & DSM)
Item Number: MAP EVO-FI-2000
MAP 2000cc fuel injectors utilize the same modified Bosch fuel injector as many of the other guys, but at a more affordable price point. These bad boys include plug and play adapters so installation couldn't be easier, however, being that these are high impedance injectors you will need to remove your resistor pack which will entail some wiring unless you pick up the resistor pack delete plug available below! Please note these are not to be used with oxygenated fuels like Q16!
Optional FIC Resistor Pack Delete Plug
To avoid cutting and splicing your resistor box harness, simply remove the resistor box and plug in the FIC Resistor Box Delete Plug. Easy! For use when replacing OEM or aftermarket low impedance injectors with high impedance injectors. ($22.00 additional)
Our introductory price: $679.99
MAPerformance Walbro 400 InTank Fuel Pump (Evo 8/9)
- Designed for engines with more than 500hp
- Award-winning OE technology
- High-pressure, high-flow performance
- Outperforms all current market in-tank fuel pumps
Pump Gas Version (F90000262) Starting at $159 or our MAP Modified Pump is $274.98
E85 Version (F90000267) Starts at $220.00
Full Blown Double Pump Hangers (FBMDP-EVO89)
Starting as low as $394.99
MAPerformance proudly offer the most cost effective fueling solutions in the industry! Chance are if you don't see what you're after in this thread we can get it and we WILL NOT be beat on pricing!
MAP AFPR Install Kits With AEM Regulator Starting at $192.99
PM Me for Exclusive EvoM Member Pricing!
: Send us a PM|||||
: NateAtMAP|||||
: Nate@MAPerformance.com|||||Click to chat for an instant quote!
MAPerformance is proud to announce the release of the MAP T4 Twin Scroll Top Mount Turbo Kit for the Mitsubishi Evo X
For real "Seat of your pants" power upgrades, Look no further then MAPs T4 Twin Scroll Top Mount Turbo Kit! Made in house from the highest quality stainless steel, fully tig welded and ported for maximum flow.
This kit is features an equal length MAP manifold, full 3" Downpipe, 2 routed Wastegate dump pipes, stainless high flow upper intercooler pipe, Dual Turbosmart CompGate40s and any T3/T4 or Garret GT Series Turbo. This turbo kit will be at home on the track or the street.
*Compatable With SST Transmission*
Includes:
Turbocharger
MAP Stainless Downpipe
MAP Stainless Exhaust Manifold
MAP Wastegate Dump Tubes
MAP Upper Intercooler Pipe
MAP 4" Intake (3.5" MAF housing)
Clamps and Couplers
Oil Feed and Drain Lines
Turbo Gaskets and Hardware
Everything Is Included For a Complete Install
Includes:
Turbocharger
Clamps and Couplers
Precision Turbo - NOW Stocking all popular Turbo's!
In an attempt to cut down delivery times for all popular turbos, PTE is now stocking on the shelf, ALL popular options so that WE can get them shipped out to you ASAP!
PM me for pricing anything and everything Precision Turbo!
Featuring the latest and greatest in compressor and turbine wheel technology from Precision, the PT6266 CEA offers a unique combination of Competition Engineered Aerodynamics (CEA) with both hot and cold sides! Offering a 30-45 horsepower increase over similarly sized turbine wheel equipped turbos, the PT6266 CEA is the perfect choice for those wanting to make more power without changing their current system.
Precision customers have a history of setting records and getting noticed. They don't sit in the stands watching the action – they're the ones making it happen. Innovation is a collaborative process and we focus our efforts on you. Get involved and be a part of the action today with .
SOME of the features PTE Turbos include are:
• Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Higher efficiency and faster transient response for maximum power and performance
• Available with either a Hydrodynamic 360° thrust bearing system, or an Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
The MAP Tubular Manifold for the Evolution X platform is now available!
Click here for initial testing that resulted in an amazing 40whp+ gain with a BBX turbocharger!
Polished
Advanced Ceramic Coating (All Ceramic Coating orders can take up to 2 weeks before shipment)
- Direct replacement for stock frame Evo X turbochargers
- 1.25" primaries for maximum velocity and spool characteristics
- Schedule 10 304SS tubing for the utmost in durability
- 304SS flanges featuring a CNC transition from cylinder head to primaries
- Available in semi-polish (pictured) or with our advanced ceramic coating
- Finish porting of CNC transition to primaries and merge collector
- Fully backpurged TIG welded construction
- Fits with OEM firewall heatshield
- Lifetime warranty against defects to the original purchaser
This integrated O2 housing downpipe, or O2 eliminator as they are often referred to, does just
that by removing some of the largest restrictions in the factory exhaust system for significant
horsepower gains throughout the power band! Features / Benefits
* Full 3" design reduces exhaust restrictions.
* Made from 304 stainless steel for superior corrosion resistance and enhanced appearance.
* Mandrel bent tubing throughout optimizes exhaust flow.
* Stainless steel flex section reduces stress from engine movement increasing longevity.
* Optimal wastegate dump location helps eliminate boost creep.
* Includes stainless steel turbo outlet gasket (not shown).
* 100% Made in the USA.
Features / Benefits
: Send us a PM|||||
: NateAtMAP|||||
Polished
MAP Stainless Steel O2 Eliminator Downpipe for Evo X
MAP Stainless Steel CompGate40 O2 Eliminator Downpipe for Evo X
Features / Benefits
: Send us a PM|||||
: NateAtMAP|||||
MAP EF Series Stock Frame Turbos for EVO X!
Named after the Fujita scale developed for rating tornado intensity, MAP's EF series of turbos are capable of delivering the power, performance, and pavement pounding mayhem that you would expect from that namesake. MAP turbos include our proprietary EF series billet compressor wheels, Turbosmart internal wastegate actuators and are capable of being supplied as brand new or upgrades to your existing turbo.
EF1
This upgrade service includes an upgraded compressor wheel, all applicable machine work, precision assembly and VSR balancing. It does NOT include an oil feed line, actuator or 3" turbo inlet pipe.
EF2
Introducing the MAP EF2 turbocharger, the smallest of our three variations. Don't let its size fool you though, this bad boy retains incredible spool characteristics and packs a significant punch up to 450whp on E85 (400whp on 93 pump gas). The EF2 is a great choice for those looking to retain some "stomp and go" in their daily driver or a corner-ripping solution for the road course or autocross.
This turbo has all the engineering MAP could throw at it including upgraded thrust components with dual oiling ports for improved lubrication, and a brand new blade profile that is super efficient and will outperform any wheel with the same inducer/exducer dimensions. What more could you possibly be after? Well if it's more power, check out our EF3 setup!
EF3
Introducing the MAP EF3, our attempt at the proverbial "best of both worlds" turbocharger. It's capable of making 100whp more than the EF2 (more than enough to add a window to your stock block should you so choose) while still retaining manageable spool characteristics for your daily driver or weekend warrior.
This turbo features upgraded thrust components with dual oiling ports for improved lubrication, upgraded thrust bearing material, and a brand new, super efficient compressor blade profile that we are confident will outperform any wheel with the same inducer/exducer dimensions. What more could you possibly be after? Well if it's more power, check out the MAP EF4!
EF4
Introducing the MAP EF4, one of the biggest and baddest turbochargers ever squeezed into a stock frame housing. Capable of 650whp on E85 (500whp on 93 pump gas) this turbocharger offers incredible spool characteristics in comparison to similarly sized T3 turbochargers due to the twin scroll turbine housing, not to mention you are able to reuse your exhaust manifold / O2 housing / downpipe making this the most affordable route to 600whp as well!
EF1
EF2
EF3
EF4
MAPerformance Clutch Master Cylinder Upgrade (Mitsubishi Evo X)
Starting at 149.99?
If you've experienced a clutch master cylinder failure or are simply being proactive, MAP is here to help. We have seen the stock plastic clutch master cylinder fail with upgraded clutches and/or spirited driving; Here is a solution that anyone should be able to install with basic hand tools from the comfort of your own garage.
With this kit there is no need to remove the pedal assembly and cut the ball joint as we include a billet ball joint attachment. Additionally, pedal height is easily adjustable by breaking loose the jam nut, removing the clip, and threading the balljoint to your desired pedal height. A braided stainless steel line replaces the original line as well.
This is a must have upgrade for Evo X owners if you are installing an upgraded clutch, don't get left stranded!
PLEASE NOTE: We offer this kit with or without a stock replacement clutch master cylinder. If you would like to include a clutch master cylinder you have your choice of aftermarket or OEM Mitsubishi. We have not had any reported issues with the aftermarket clutch master cylinder and offer it to you as a cost effective alternative to the OEM unit.
Starting at 149.99?
MAP offers stock replacement, short runner, tubular manifolds for both the EVO 8/9 AND the EVO X!
Our new tubular stock replacement exhaust manifold is made of high quality mandrel bent SUS304 stainless steel and electronically tig welded at all joints. Our manifold is designed to retain your factory turbo orientation. The shorter length runners help to increase spool while still allowing for big power gains up top!
EVO 8/9:
EVO X:
EVO 8/9:
EVO X:
MAP is proud to offer Injector Dynamics brand new line of 1300CC rated injectors!!
The ID1300 is an all new injector, designed in partnership with Bosch Motorsport
This collaboration has given us the ability to design a high flow injector with characteristics specific to the needs the high-performance tuner.
The ID1300 was designed with alternative fuels in mind, and is the only performance injector available with all stainless internals. It is compatible with all known fuels, and will stand up to the corrosive nature of alcohol better than any injector on the market.
While the ID1300 was designed with an eye towards ethanol fueled engines, we have accounted for the occasional need to convert back to gasoline. The ID1300 has a minimum fuel mass compatible with gasoline use, and will provide exceptional idle and cruise behavior under these conditions.
In addition to its multi-fuel capabilities, the compact body of the ID1300 allows fitment in 200+ applications, making it the most versatile injector in our lineup.
Follow the shortcut links below for specific data, or scroll down to see all data for the ID1300.
Basic Specifications
Nominal Flow Rate - 1340cc/min @ 3.0 Bar (43.5 psi) Using Iso Octane at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 6.0 Bar (87.0 psi)
Fuel Compatibility - Compatible With All Known Fuels - (Designed Specifically for Alternative Fuels)
Electrical Connector - USCAR
MAPerformance updated inventory clearance!
We just recently updated out inventory clearance section on our website and there are some pretty awesome deals to be had for just about every car you can imagine.
Inventory Clearance Special!
EVO X
EVO 8/9
Again, I'm linking you directly to the EVO sections, but we have everything from DSM to Camaro to Subaru at amazing deals and discounts! Click below to check out the entire clearance!
EVO X
EVO 8/9
Exedy Cerametallic Stage 4/5 Triple SR Clutch Kit (Mitsubishi Evo 8/9) MM023SR
IN STOCK HERE and ready to ship!
That's right, I literally have too many of these kits in stock. PM ME, NATE for the best pricing available! I won't be beat in pricing!
And while we are on the topic, I ALSO just got a HUGE shipment of twins in here...truth be told, I am worried I might have bought too many of those too...so if you are in need of an Exedy twin, shoot me a PM! I am motivated to reduce that inbound shipment a bit!
Exedy Cerametallic Stage 4/5 Twin HD Clutch Kit (Mitsubishi Evo 8/9) MM022HD
So once again...just to clarify...I got an amazing deal on SR Triples and HD twins and I think I might have purchased too many! PM ME if you want one...I have about a dozen of each I would like to get out the door and I am GOING to blow them out the door!
Polished
Features / Benefits
: Send us a PM|||||
: NateAtMAP|||||
Polished
Features / Benefits
: Send us a PM|||||
: NateAtMAP|||||
EVO X
EVO 8/9
EVO X
EVO 8/9
MAPerformance - Proud to be your number one source for ALL COBB Including NEW EVO X
552311: Mitsubishi Evo X Turboback Exhaust w/ Oval Tip Cat-back
Product Code: 552311
Retail Price: $1,745
COBB 3" SS Downpipe
COBB 3" SS Testpipe
COBB 3" SS Oval-Tip Catback Exhaust
652X2O: Mitsubishi Evo X Stage2 Power Package w/ Oval-Tip Exhaust
Product Code: 652X2O
Retail Price: $2,049
COBB Accessport
COBB 3" SS Downpipe
COBB 3" SS Testpipe
652X3O: Mitsubishi Evo X Stage3 Power Package w/ Oval-Tip Exhaust
Product Code: 652X3O
Retail Price: $2,425
COBB Accessport
COBB 3" SS Downpipe & Testpipe
SF Intake System
Silicone Turbo Inlet Hose
3-Port Boost Control Solenoid (EBCS)
652X3Q: Mitsubishi Evo X Stage3 Power Package w/ Quad-Tip Exhaust
Product Code: 652X3Q
Price: $2,425
COBB Accessport
COBB 3" SS Quad-Tip Catback Exhaust
SF Intake System
SHOOT ME A PM for details or pricing!
